Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 07-23-11, 11:09 AM
  #151
aznpapaya
aznpapaya's Avatar
i installed the amp and subs and they are working perfectly, the only problem now is that for some reason my amp gets really really hot, i would take a 1 hr drive and you can literally fry and egg on it lol. I search and most people said that the main problem could be because of a bad ground. Yesterday I took everything apart and rewire everything, i found what seems to be a much better place for the ground, i found this screw that's screwing down this clip which appears to be touching the frame of the car . But my amp is still getting really hot really fast. Any recommendation on where you guys ground your wire?
here's a pic of where i ground my wire, i know it's not exact but just to give you guys the general idea where i ground my wire.
http://www.flickr.com/photos/55999657@N04/5967723590/http://www.flickr.com/photos/55999657@N04/5967723590/ by http://www.flickr.com/people/55999657@N04/, on Flickr
Old 07-23-11, 11:13 AM
  #152
kumquatism
kumquatism's Avatar
Did you sand down the area before you grounded it down?
Old 07-23-11, 11:29 AM
  #153
aznpapaya
aznpapaya's Avatar
no i did not. but the place where i ground it seems to be bare metal tho.
Old 07-23-11, 12:58 PM
  #154
sushiboi
sushiboi's Avatar
I also need a better ground location. I used a place under the back seat.
Old 07-23-11, 02:29 PM
  #155
Supernin
Supernin's Avatar
Ground location can affect sound quality, but a bare metal ground is probably not causing it to get really hot. Causes for that are:
1. internal fan not working - check that first (if it has one)
2. inadequate air space around on the amp, particularly the heat fins which need plenty of air around them
3. pushing it really hard at a high gain will do it too; not much you can do about that except get a more powerful amp that doesn't have to work as hard.
hope that helps
Old 07-23-11, 02:46 PM
  #156
aznpapaya
aznpapaya's Avatar
hope that helps
superin, thanks for the input but:
1. The fan is working, i can hear is running.
2. there's nothing in my trunk except the amp and sub, i didn't mount it upside down either. It's just sitting there in the trunk with a whole lota space to breath lol.
3. my gain is at currently at 60%, 70% max, but i'll try to turn it down more to see if it helps with the heat problem.
I'm also intereted in a better grounding location if anyone want to share their.
Old 07-23-11, 04:22 PM
  #157
joeker
joeker's Avatar
if you remove your passengerside trunk carpet/panel(requires removal of a couple of clips), there is already a ground location which is used for factory electronics.
Old 07-23-11, 06:33 PM
  #158
aznpapaya
aznpapaya's Avatar
can you be a little more specific, or perhaps a picture would be great.
Old 08-16-11, 12:40 AM
  #159
Supremancy
Supremancy's Avatar
Another reason for an amp to run hot is your sub configuration...Check your amp and see what impedance should be at the terminals (should either be 2ohm or 4ohm) and then see what resistance your sub is. If it is too low then it will overheat your amp with in like 5 to 10 min.
Old 08-18-11, 09:27 PM
  #160
Likwid XTC
Likwid XTC's Avatar
finshed it today after a few 30 minute sessions here and there total was probably 5 hours cause im working with my son as well.lol
i had to fish through the whole post to find out what i need so ill list everything i did for the non ml version
i used a
scoshe 4 channel LOC
i tapped both set of wires from the oem subwoofer (going left to right on the amp plugs)
located on the second plug
brown + and green -
pink + and sky blue -
remote wire
located on the third plug
orange wire all the way on the end
after that it should be very easy and basic if you installed a system before, rca ,power wire, and ground.
and the end result
(all the wires are cleaned up and hidden, i had extra that i just cut off and left it there as i had to tend to my son)
Attached Thumbnails DIY aftermarket amp power wire install step by step with pictures-img_0761.jpg   DIY aftermarket amp power wire install step by step with pictures-img_0762.jpg
Old 08-18-11, 09:31 PM
  #161
Likwid XTC
Likwid XTC's Avatar
also the enclosure is wrapped in white carbon fiber vinyl wrap
Old 08-25-11, 12:14 PM
  #162
IS3003o3
IS3003o3's Avatar
So just started doing this for my '11 non ML and there seems to be a problem..
Old 08-25-11, 06:40 PM
  #163
bfedro427
bfedro427's Avatar
Originally Posted by 06tpis350
Hi, quick question..tell me if I'm right=] what Im understandin just hook the sub wires green - and brown + from ml amp into loc. My question is. Does matter were the wire goes on the loc. Like for example to rear left speaker - and + goes on loc slot a5+ and a6- which is + and - equals to green - and brown + ml sub wire. Then for the RCA I choose the rear left speaker. Would I need to hook up a Y RCA to have a left and right that goes to the aftermarket amp. Please tell me if Im right ? Help Cl. Thank again on advance=]
Can anyone post a pic of what the y-splitter looks like and how it is connected?
Old 08-25-11, 10:51 PM
  #164
IS3003o3
IS3003o3's Avatar
so the '11 non ML systems do not have any orange wires. I didn't have any meters or anything so I couldn't test the wires for a remote line. I ended up getting the 4 channel LOC from Wal-Mart and ended up tapping the subwoofer wires (brown & green, sky blue & pink, yes both pairs for non ML). also tapped the cig lighter fuse for remote right now everything is fine. its all a matter of adjusting everything
Old 08-26-11, 04:23 AM
  #165
bfedro427
bfedro427's Avatar
Same here...don't see any orange wires period. Mind posting a quick diagram of how you wired it to the LOC? Seems to be a bunch of conflicting information as far as whether to do both pairs for non ML
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
