Old 12-15-14, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Electrical HELP!!! (Windows won't roll up after battery disconnect)
Old 05-28-08, 02:14 PM
javyLSU
2IS OG
javyLSU's Avatar
Welcome to Club Lexus. Please take a look at the 2IS FAQ thread stickied at the top of this forum - this has many of the answers that are repeatedly asked (and answered).
Javier
Old 02-28-10, 09:54 AM
Zmiley
Zmiley's Avatar
When the battery is disconnected, the power windows must be initialized in order to ensure proper operation.
here is what to do in simple terms:
1. open driver side front window halfway
2. close driver side front window and hold switch for 1 second
3. have a look at the other door window switches (they should be flashing)
4. repeat same procedure with other 3 window switches
Easy enough
Old 05-13-10, 09:38 PM
funglenn
funglenn's Avatar
What about rear view mirrors----ever since I disconnected the battery to install the Ipod adapter now my side mirrors will not loook down in reverse. I did manage to get the windows and sunroof to work just fine, but not these.
any ideas?
Old 05-13-10, 09:43 PM
JDKane527
JDKane527's Avatar
any ideas?
Look to see if the mirror selector, the 3 way switch that is either L, none, or R is in the middle position, if so that's why it won't work. If you have it set to either L or R then it will work again.
Old 07-02-10, 09:14 AM
1fast350
1fast350's Avatar
Default Pwr windows not working
Hey guys, I know that there is a process for resetting the window but I thought that it is only when the windows dont work at all. I have only the driver door working up and down with none of the other windows working from the driver switch or the window switches on the doors. I just wondered as the car was disassembled without the battery if any one has had this problem before?
Old 07-02-10, 09:20 AM
quick123
quick123's Avatar
are the window switch lights blinking???
Old 07-02-10, 09:42 AM
javyLSU
2IS OG
javyLSU's Avatar
Next time try taking a look at the stickied FAQ/DIY thread. It contains this link answering that question, which might well be the most frequently asked question in this forum.
Javier
Old 07-02-10, 09:53 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
^^ LoL.. you deleted my post!!! I want it back up....
Joe Z
Old 07-02-10, 09:56 AM
javyLSU
2IS OG
javyLSU's Avatar
I haven't deleted any posts Joe...
Javier
Old 07-02-10, 09:58 AM
Joe Z
Joe Z's Avatar
Javier
Ah crap.....my bad.. I hit submit while you were doing your magic.. LoL
Old 07-02-10, 10:01 AM
Joe Z
Joe Z's Avatar
Lightbulb
This will happen every time you disconnect the battery terminal(s).
Follow the very helpful steps in this thread for resetting each switch.
If that doesn't work, make sure your child window lock button on the master switch is NOT pushed down..
***As that will prevent you from resetting the switches.
Joe Z
Old 07-02-10, 10:08 AM
cdeeznuts
cdeeznuts's Avatar
woo hoo for zombie thread... up 3years old weee.
Old 07-02-10, 10:43 AM
Joe Z
Joe Z's Avatar
Talking
Its called moderator thread merge bro....
Old 10-04-10, 03:13 PM
chikoo
chikoo's Avatar
Originally Posted by ReLexin
roll them down half way using the switch on each door. and then on the roll up hold it till you hear a beep sound than the windows with work from the drivers controls. i was freaked out by this too.
WTF....any reason behind this madness?
Old 10-04-10, 04:09 PM
Kurtz
Kurtz's Avatar
When you disconnect your battery it loses track of
"where" the window is in its travel.
So you have to calibrate/reset that.
It's not needed on 09+ models as those have flash memory (seriously) in each window controller to remember the position even after loss of power.
Quick Reply: Electrical HELP!!! (Windows won't roll up after battery disconnect)
