can i fit 19x9 30 offset Rear 19x10.5 32 offset wheels on a 350?
Old 05-24-07, 11:28 AM
IS_NIICE
IS_NIICE's Avatar
Default can i fit 19x9 30 offset Rear 19x10.5 32 offset wheels on a 350?
what do you guys think?
Old 05-24-07, 12:08 PM
Gernby
Gernby's Avatar
Nope. They would stick out too far.
Old 05-24-07, 01:34 PM
IS_250
IS_250's Avatar
i think the front could, with a stretched tire.. not sure about the rear, but with negative camber, some fender work and a stretched tire it can probably happen.
not sure that what you want to do though..
Old 05-24-07, 04:31 PM
solo_stage
solo_stage's Avatar
i really wouldnt go past +35 offset... unles u want the super flushed look. and with that kind of offset and width in front you need to basically beat the hell out of ur fender (roll fenders) and super stretch the tires..
the rear should be okay.
Old 05-24-07, 07:57 PM
IS_250
IS_250's Avatar
i disagree, i dont think the rears will be okay with a 10.5" wide and 32mm offset. the rear fenders will need to be shaved/rolled and a tire will need to be stretched on. the most aggressive ive seen is a 9.5 wide 38mm on a 275/35/19 + a 10mm spacer making it a 28mm offset. this car still required mods to the rear fender.
regardless, id love to see the outcome.
notserp
02-24-12 03:53 PM
Gs430Boi
03-11-08 08:52 PM
Rare1
Wheels, Tires & Brakes Forum
10-21-07 06:16 PM
2jzz30
02-12-07 08:53 AM
punch10
34
04-16-06 06:48 AM
Quick Reply: can i fit 19x9 30 offset Rear 19x10.5 32 offset wheels on a 350?
