Can't spin the tires
Old 04-17-07, 12:45 AM
LexyIS350
LexyIS350's Avatar
Default Can't spin the tires
I found myself in a nice empty parking lot this sunny afternoon. I was bored so I decided to see what would the Is 350 do if I gun it from a dead stop. I got traction immediately and took off like hell, which is a good thing. However, I'm wondering do any of you guys peel off when stepping on it from a dead stop? I also did the pedal dance and turn "power" mode on, but I still wasn't able to break the tire loose.
Now before you guys tell me it's a waste of a good tire or it's not the quickest way to take off, I'm aware of that. I just wanted to see if it's possible.
Thanks
Old 04-17-07, 01:30 AM
Hartawan
Former Vendor
Hartawan's Avatar
I am now able to make the tire break loose at start because I am running low on tread.
Try this. Step on the brake pedal while accelerating, as soon as your tires break loose, let go of your brake and keep accelerating. Have fun and be safe.
Old 04-17-07, 03:56 AM
IS_Mine
IS_Mine's Avatar
Brake boost to aout 1500 RPM then let it go.
Old 04-17-07, 03:58 AM
dafidav
dafidav's Avatar
turn off VSC?
in the 250, i turn it off and hold break for a bit and i can get a tiny wheelspin
Old 04-17-07, 07:59 AM
cancellino
cancellino's Avatar
On the 07' 350 you can hold the trac button down for 10 seconds and forgo the pedal dance (both lights should be lit). The traction control will stay off and you should be able to break free; mine will.
Old 04-17-07, 08:02 AM
Gernby
Gernby's Avatar
I wasn't able to break my tires loose until I had several thousand miles on the engine.
Old 04-17-07, 09:19 AM
LEXCESS
LEXCESS's Avatar
I'm surprised. I can blow the tires off my 350 sport pack anytime and I got the car a week ago. It's only got 900 KM on it right now. I found that disabling traction control will easily allow you to get it sideways and spin the tires.
Old 04-17-07, 09:25 AM
15951's Avatar
I'm sure it has to do with a number of things - temperature, road conditions, tires. You're in colder temperatures, and I'm guessing you might have all season tires?
I have the Dunlops, and have yet to break traction from a standstill at 4k miles unless I floor it around a corner. I consider this a positive attribute...I'd rather be moving than standing still with my tires smoking.
Gernby
Gernby's Avatar
What type of surface? Do they break loose in a straight line just by flooring it even on a grippy surface?
Old 04-17-07, 09:53 AM
rroy
rroy's Avatar
I just give her a lil gas and pop the clutch and she'll chirp easily in first and second. Add a little sand and disable trac and they'll spin
joel2000
03-27-19 07:03 PM
TruPlaya26
08-20-07 12:26 PM
ALEX_IS350
07-20-06 05:38 AM
Madasian87
GS - 1st Gen (1993-1997)
02-24-05 11:35 AM
GS400kid
Performance
04-15-03 10:49 AM
Quick Reply: Can't spin the tires
