Yet Another DIY Oil Change for IS350 (w/pics)
Old 04-17-07, 05:37 PM
GreyHound
GreyHound's Avatar
Default after 4k miles
just keeping an eye on the filter. less waste than a spin on can filter. what's old is new again. In the 50's everything was canister filter.
Attached Thumbnails Yet Another DIY Oil Change for IS350 (w/pics)-100_09.jpg
Old 04-17-07, 09:14 PM
combfilter
combfilter's Avatar
man great write up and great pics. Thank you very much!
Old 06-23-07, 11:27 PM
javyLSU
2IS OG
javyLSU's Avatar
Originally Posted by brel523
I let alot of the oil drain first by just cracking it a little since I was sure how much was going to come out.
Once the oil filter housing was fully loose, I just set it in the drain in the pan. Took picture of housing removed also.
That's exactly how the factory service manual says you should drain the oil from the filter. If you look at the threads on the filter housing, you'll notice that there is a section where all the threads are flat - it's a little blurry, but you can see it in the second picture above. This is a design feature that allows you to turn the filter housing so the flat section faces toward the bottom, allowing the oil to drain out controllably from the oil filter.
Javier
Old 07-10-07, 03:35 PM
shyishguy
shyishguy's Avatar
Where can i purchase that Oil pan/bucket shown in the picture?
Old 07-10-07, 04:25 PM
mtnduc
mtnduc's Avatar
I can't believe you guys buy a $40K auto and change your own oil.
If the dealer is too expensive just go to a quick lube.
Old 07-10-07, 04:34 PM
Caoboy
Caoboy's Avatar
I wouldn't trust the quick lube places. They tend to not tighten the filter enough, and I'd rather use a filter/oil of my choice than the stuff they use.
Old 07-10-07, 04:54 PM
brel523
brel523's Avatar
Purchased that one from AutoZone.
Old 07-10-07, 05:08 PM
brel523
brel523's Avatar
I used to have the "quick lube" shops do my oil change until they over tightened the bolt to the drain pan and stripped it. Then they blamed me for putting on the wrong bolt last oil change, but then I reminded them THEY changed it last time. They still refused to pay for the fix. Once I said I was bringing a lawyer into the picture they finally paid the towing fee to the dealer and cost of a whole new oil pan and labor totaling $375.
Since then I've done my own oil changes. Will NEVER take my cars to a quick lube shop again and will not give the Lexus dealer $100(that's crazy) to do an oil change. I can buy the oil and filter for ~$40 and have it changed myself in 30 mins. Doesn't bother me to get a little dirty and feel good knowing it was actually done.
If I'd never had that incident, then I'd probably still be having the quick lube shops do it, but it only takes one time to mess it up. I've had my one time.
Old 07-10-07, 06:57 PM
tw88
tw88's Avatar
It's not always about the price. It's doing it yourself and knowing that it was done right (or even done at all).
Old 07-10-07, 07:04 PM
javyLSU
2IS OG
javyLSU's Avatar
Let's try to stay on-topic, guys - how to change your own oil. If you want to debate whether you should change your own oil or not, there's another thread for that.
Javier
Old 07-10-07, 08:47 PM
wolverine
wolverine's Avatar
wow thats ****ing dumb. what if someone prefers to do that **** on there own? why pay someone when I can do it myself.
is the toyota filter remover the same as the snap-on one?
Old 07-10-07, 08:51 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Yes, it is. The Snap-On piece just costs a lot more.
Old 07-10-07, 08:53 PM
wolverine
wolverine's Avatar
how much difference? i got the snap-on one for $18
Old 07-10-07, 09:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
This might be painful. I love Snap-On, but they are far from the least expensive solution for some things. I'll still buy their sockets without batting an eye because they always fit in tight quarters, but some of their stuff is just plain ridiculous.
Old 07-10-07, 09:35 PM
wolverine
wolverine's Avatar
hmmmmm o well. I have alot of snap-on tools (me mechanic) so when the truck came i asked for it
Quick Reply: Yet Another DIY Oil Change for IS350 (w/pics)
