Custom Sound Systems
Old 08-10-15, 02:52 PM
valeoray
valeoray's Avatar
Originally Posted by IBIS250
IDK why, Ive been reading theough the forum posts and im reading some say they relocated it to the glove box, maybe something about keeping the A/C functioning properly, right now im so confused, All I can figure right now is that Im going to have to do my own custom wiring because I cant seem to find anything that will plug into the factory harness for speakers and such, im just not finding the indo I need to unconfuse me
I realize the top of the stereo has the AM/FM and A/C, so I don't know how the CD would affect anything. Anyways I do not know enough about the system. Obviously people kept the CD for some reason.
Old 08-10-15, 04:18 PM
IBIS250
IBIS250's Avatar
Valeoray
According to the Lexus techs at work, that lower section with the CD player is considered the headunit, everything else works off it, so if you unplug it and get rid of it, the radio doesnt work.
But Ive got,it firgired out now, I relocate that lower section to the glove box, Ive got a replacement for the lower section from Amazon that allows a sogle Din radio to be put there, it even matches the color of the center section, then I will install some subs in the trunk, found a sub enclosure for the IS on Ebay, then I will imstall 2 Amps, the amp I use for the main speakers, I can pick up the speaker wires right there at the factory amp thats already in the trunk, then I will have my custom audio system, if the factory speakers cant handle it, I will replace them
Old 08-10-15, 04:57 PM
valeoray
valeoray's Avatar
IBIS250,
So you will be splicing in the new single DIN radio to the existing harness? or how do you add a new radio to the existing?
Old 08-11-15, 05:06 PM
IBIS250
IBIS250's Avatar
Veleoray,
Once I put the new headunit in, up front all I have to,wire up,is the power, ground, memory power ect., And run The RCA cables tomthe trunk for the amps, I will unplug the speaker wires from the factory amp,in the truck and make me up a pigtail to plug into the factory speaker wires, the factory radio will still be there in a sense, but it will just be unused in the glovebox to keep my a/c functionimg
Old 08-12-15, 09:40 AM
valeoray
valeoray's Avatar
IC. So you're keeping the stock stereo intact just for the A/C. Then you'll install a new amp and plug the stock speaker wire inputs into your new amp.
Great! Please report back on your progress.
Old 08-13-15, 07:09 PM
IBIS250
IBIS250's Avatar
Valeoray,
You ever hear of Tommy Gilham and the Chill Billys up there?
Old 08-13-15, 07:38 PM
Slammer1
Slammer1's Avatar
The HVAC controls do run through the CD changer, which is why I removed the frame of my factory changer and tucked it behind the upper portion of the display when I did my custom install 4 years ago.
Old 08-14-15, 09:40 AM
valeoray
valeoray's Avatar
Valeoray,
Nope. Who are they?
Old 08-15-15, 06:29 PM
IBIS250
IBIS250's Avatar
Valeoray,
Tommy Gilham is a friend of mine that moved up to Canada and is a country music star up there, i guess in
Some places up there
Old 03-30-24, 07:50 PM
bclex200T
2nd gear
bclex200T's Avatar
Default I’m looking for a fit that doesn’t take up the whole trunk
Originally Posted by is_elf
Yes and they suck...100 Threads out there an no pics...
That is why I possted this one...I want to see things like this:
where can I get this setup?
RoyalOne
Build Threads
10-01-14 11:52 PM
cjones4640
09-26-07 02:27 PM
jtgs400
08-30-07 04:06 PM
lexoman562
06-12-06 08:10 PM
Gs Dreams
18
08-18-04 08:25 AM
Quick Reply: Custom Sound Systems
