MP3 DVD's can somone explain PLEASE
How do you burn mp3 files on dvd's?? and how do you get the mp3 folders. I tried burning it with nero by burning with the mp3 dvd option but it didnt work.. HELP!! thanks
I'm confused...are you trying to burn MP3 songs onto a CD or are you trying to burn movies onto a DVD and play it in your car's player? If it's the first option, you just record the MP3 songs onto a CD using the "data" recording mode and that's it. If it's the latter, you have to use a special type of program to first convert the movies and then burn it onto a DVD. I'm not an expert on this topic so if someone else have more info on how to convert the movies, please chime in.
i use nero for my is350. it works perfectly, except the whole name doesn't show. what kind of nero? i use NERO burning ROM. basically, wen you enter nero..a screen shows up with the CD-ROM(Iso) u use that to burn the cd for MP3..BUUUUTT that is for CDs...i dont know about DVDs..hope that helps
There are several threads about this. Do a search. Basically you will have to first convert the MP3s into a different format. I haven't had to do it yet. 6 MP3-CD's are enough for me.
yeah im talking about mp3's on a DVD... I only found this thing
https://www.clublexus.com/forums/sho...d.php?t=261156
are there any other programs out there?
to burn/use MP3s on a DVD in yourLexus use the following program:
Audio DVD Creator (because there is a difference between Audio-DVD and DVD-Audio - first one works with your lexus, second one not)
here is the link:
http://www.audio-dvd-creator.com/index.htm
greetings from vienna
here is the link:
A DVD-MP3 is a DVD that is created with and contains only digital audio files in the MP3 format. As far as I know, none of the OEM dvd players available in cars today can play this type of DVDs. Actually not all home DVD players can play DVD-MP3 discs.
The DVDs created with Audio DVD Creator are just regular DVDs consisting of only the audio files (without MPEG-2 compress video data file). It's your regular DVD Video Disc without the mpeg video file just the audio. If you burned a DVD-R by converting your mp3 files, then, you don't have a DVD-MP3 disc. You'll have a DVD Video Disc without the video file just the audio .ac3 files (stored as VOB files).
It's like playing a DVD Video Disc in your regular DVD Player with your TV off. That's it, that's what you have.
One last thing, DVD-Audio its a whole new story. For a detail explanation go to this link:
http://en.wikipedia.org/wiki/DVD-Audio
Liquid Bra Champion
Contrary to what some will tell you (ie. Technique), the ML will NOT play MP3 DVD's. There is software that will convert and burn MP3s to DVD-A (MP3s -> AC3), which will play in the ML.
i would like to understand this also. i use the iTunes software and i followed the instructions but it wont allow me to burn them as MP3 format? i was just recently told that the songs on that are locked so you dont share them? i have an Ipod but find its a pain to use when driving and would rather have a few MP3 cds that i can use on the head unit. has anyone done this??? please let me know if you have any ideas on how to make this work!
thank you
thank you
2IS/2RX/4RX
thank you
thank you
