Tire Light still on w/OEM rims back on???
Ok so I put my Factory rims/tires back on, and the "check tire system" light, "!" light, and the "low tire symbol" still stays on ?! I had aftermarket rims on and the warning lights all lit up, now my OEM ones are on and still same lights are on? WTF! Does the dealer need to reset em? And yes the tire pressure is correct in all 4 .
I very much doubt it. Use your satellite switch. Make sure the 1st sensor set is selected, and then re-initialize the pressures by holding the switch down. It's a bit tough to explain, but it's painfully obvious when you're sitting in the car playing with the switch.
Satellite switch, where is that.Thanks for the info.
Tech Info Resource
Not days - minutes. See below:
