Any one using spacers?
Did a search and found one good thread about wheel spacers. Now that my car is dropped and will be sticking with the stock wheels I would like to push them out a little. Any suggestions. I was thinking 5mm front and 15mm rear.
I was thinking about the same thing. 5 & 15 sounds about right. I work for machine shop so I can make a set myself. I just worry about stud length. 15mm is over half inch so I would have to install longer studs. The problem is that Im switching between snow and summer wheels and if Ill mount longer stud, my summer wheel lugs will no longer hold the rim tightly. and I dont know where to get those weird looking /washer/ lugs which are deeper than stock by over half inch
regards, Bart.
regards, Bart.
I added 5mm for front and rear, +42 and +43 offset for front and rear, I wanna to get a bigger spacer for the rear...I added 30mm before but it was too big it rub the fender...
