Expensive Oil Change
Went to the dealer today and I paid $65.00 for an oil change...wow!!!
Also, bought one of those AC filter for $38.95..they wanted to charge $61.95 for it. Is this easy to change?
if you have a 06 IS i cant imagine you need an AC filter change yet... i believe the AC filter can be accessed behind the glove compartment. my local Lexus dealer charges about the same and including the Evinronmental fee and taxes its about $70. this also includes synthetic oil as well. if they are charging you $65 for regular dino oil, i start taking it to a local toyota dealer.
The A/C filter is just for fresh air, not recircultaed air, right? If so, I can't imagine it needing to be changed unless air flow is not what it used to be. As long as you are satisfied with the amount of air that is blowing, you are actually better off with a dirty filter. Dirty filters do a better job filtering.
Super Moderator
Originally Posted by Bichon
Without filtering, dust from the cabin will coat the moist evaporator coil, eventually clogging it.
I replaced the microfilters (pollen filter) to all my car once a year at most, typically at the beginning of the spring. That is when it is needed the most IMHO to filter the pollen (I am not alergic to pollen, but my GF is).
Also, I am not sure if you all are familiar with this practice.
Eveytime i change the filter, I spray lysol disinfectant to the housing of the filter + the filter itself.
Then run the heater on high for 5 minutes or so with the windows down. The purpose is to dry out the circulation system so that fungus + mildew that grow inside the system will be killed. Do you recall that '**** smell' that you get at the beginning of winter after your AC has not been on for 3 months? That is fungus/mildew smell all right.
Just get a can of oderless Lysol or my personal favorite is the Spring Smell Lysol.
On another note, the A/C shouldn't be left off for such long periods of time. It should be run at least once a week to keep the gaskets in good shape. However, I imagine the IS will automatically run the compressor when the defroster is used, even when set to full heat.
How do the filters look when you replace them after just one year? Do you realize that clean filters do not filter as well as dirty ones, so you are actually allowing more pollen through? I hope you aren't replacing the engine's air filter so often, or you will be replacing the engine more often as well.
I change my engine filter typically between 15K - 20K on all my vehicle.
But i am not aware to the fact that clean filters do not filter as well as dirty one.
Perhaps what you mean is the pre-oiled clean filter perform better?
Indeed in general the cabin filter looks a bit dirty but not too bad after 1 year. Depending where you are located and the amount of driving you do and the amount of pollen in your area etc.
That is why i mentioned "replace once a year at most" in my original post.
It is quite common for me to change the filter after I went through 2 winters. i.e summer - fall - winter - spring - summer - fall - winter - spring <change filter here>.
Pollen is a lesser problem where I lived in midwest few years back.
Now, in MD Eastern Shore area there seems to be a lot more pollen in the spring air.
And humidity is pretty high too, promoting the growth of fungus and mildew.
