HID Bulb Installation(HELP!)
MTEC HID Bulb Installation
I'm currently installing my MTEC 6000K HID bulb and the damn thing doesn't want to lock in place on the housing. The link below should explain why. Either I'll wait and get the correct one from the seller or use a Dremel. Any other ideas?
http://share.shutterfly.com/action/s...=1153594301835
Originally Posted by jewel
I installed my fogs no prob, gonna try to install my hids (mtec) tomorrow... what type of problems are you having?
Yes, it says H11 on the box. Goodluck turning the driver side with pliers. They should turn by hand with no problem, just like the stock bulbs. Also, I'm afraid I might break them if I turn too hard. Can you put your stock and MTEC bulbs side by side and let me know if the tabs are the same thickness? I really think I got the wrong bulbs. There's no way these will lock in the housing. I was able to resize the pic. Left side is stock, right side is MTEC.
My bulbs are EXACTLY like yours. Just finished my install in under less than 3 hours. The bulbs will not turn by just twisting it, I had to use pliers for leverage and it turns easily with the pliers... I'm no wuss either :P
Does anyone elses HIDS hiss when they turn on? Only for like 10 seconds and it goes away... but it scared me when it was hissing :P
After driving around at night, they sure look better than stock. From very far away, they're kinda bright. People may think I have my brights on. The 4750k fog bulbs does not help though. I turned them on and off, and there's not much difference because the HIDs over power them. Overall, I'm satisfied.
The fogs were noticeable when I had just my stock halogens, now they're just to make my car pretty. I got the 6000k HID's and they seems to have an aqua tinge, and not a blue one.... but it looks nice. The jagged lighting pattern of the halogens seems to have gotten worse tho =/
the exact same thing happened to me with my MTEC kit also. Instead of doing the smart thing and using pliers, I actually took a dental handpiece and recontoured the tabs. I was too lazy and didn't even put the dust covers back on, I just left it open..... 3 months and multiple HEAVY rainy days later, still no condensation
ps I drill and fill for a living so did what came naturally
nice :P
i would use the dustcover tho... save you some hassle later
As for the bulbs, just found out there are two types of MTEC H11s. One is with the thicker tabs, the other with thinner tabs. This is what the seller told me. I thought the guide (or whatever you call it) in the housing is what was preventing the bulb to go in and turn clockwise because the tabs are too thick. If you put it side by side with the stock bulbs, I still dont understand how it turned using pliers. But it did. Did we just force it in there?
