HELP! Cannot roll passanger windows up or down!
Ok, following the instructions for the Joez intake, I unplugged the battery for 20 minutes. The problem is that after I plugged it back in, I can only control the driver window and NONE of the passanger windows from the driver seat. Further more, I have lost the auto up feature. What happened?!?!
Have you tried rolling it down from the passenger side? My car did this when I first got it home from the dealer. If you roll it all the way down and then back up it seemed to work.
If that doesn't work, take it to the dealer.
11 Second Club
Yes you will lose control from the drivers side door after resetting the car. You have to go to each door and push the up and down window button and that will allow you to once again control all the windows from the drivers door. I freaked out when that happened to me too, but it's not biggy.
You have to re-initialize the windows. I forget the exact procedure but you have roll the windows down halfway or something and then roll them up all the way for each and every window.
Well I can roll them down from the passanger's own control switch, but still can't roll them down or up from the driver side. Auto up/down does not work at all on any switch.
you have to go to each window, roll it half way down...leave it, go to the next one, then the next....and then go back and roll them up all the way in the order that you rolled them down the first time. Only go half way. ITs a safety feature on the car. if you push the auto up on any of the windows and you hand or arm is in the way when it hits the top, it senses the pressure and rolls the window back down, so it doesn't crush your hand. If that ever happens where it has to go back down, you will have to do that reset again.
Fortunately, I read about this problem before I installed the Joe Z, or I would have really freaked . Probably would be nice if there was a warning or something on the bottom of the instruction page letting you know this is going to happen, for those who hadn't stumbled across this on the forum.
aristo2369
10-19-09 11:04 AM
