ISP Mode & G Spider as Light as Rays Volk Wheels?
Old 03-24-06, 09:38 AM
dsdfan
dsdfan's Avatar
Default ISP Mode & G Spider as Light as Rays Volk Wheels?
When my IS250 arrives, I will replace the stock 17" wheels with 18" wheels.
I plan to install Rays Volk Rims, either CD28N, SF Winning or Gramlight 57FPro.
For Hub centricity, I am also considering Lexus original ISP Mode and G Spider rims.
Questions:
Are the ISP and G Spider rims as light as Rays Volk Rims?
Will the ISP Mode and G Spider rims offer equally good acceleration and handling as Rays Volks Rims?
Between the ISP Mode and G Spider, which performs better.
Thanks for the advice.
Old 03-24-06, 10:00 AM
4TehNguyen
4TehNguyen's Avatar
if youre worried about hub centricity you can always put in some hubcentric rings, many people here have volk wheels that fit fine. I dont think the OEM offered wheels will weigh any less than true aftermarkets nor do they look as good. Stick with aftermarket
Handling in terms of wheels you cant really argue that, obviously if you have OEM 17" vs aftermarket 18" the 18" is going to have a thinner and/or wider tire, and obviously there it outhandles stock but that gives more credit to the tires more than the wheels, the wheels accomidated the tires tho
Old 03-24-06, 10:04 AM
uschardcor
uschardcor's Avatar
grams are one of the lighter wheels in the industry and rays overall is probably the best lineup out there that you can buy...if you really want light go with ray/gram
Old 03-24-06, 10:18 AM
dsdfan
dsdfan's Avatar
Thanks for the very helpful advice.
To clarify, I am wondering if the handling and acceleration of the 18" ISP Mode will match that of aftermarket 18" Rays Volk Rims. Thanks!
Old 03-24-06, 01:10 PM
yellowssm
yellowssm's Avatar
The handling and acceleration will be better with the rays/gram because they are lighter. Will it be that much better, or better yet will you be able to tell the difference in performance and weight? Probably not. I got my volks on order and wouldnt even consider the OEM wheels because I think they are ugly. My .02
Old 03-24-06, 01:13 PM
4TehNguyen
4TehNguyen's Avatar
well the rays volks can accommodate wider and thinner tires when getting the proper size so you will get new tires and definately outhandle stock ISP. Volk wheels might not cost that much more than ISP wheels, plus they would look more custom for your car
Old 03-27-06, 10:16 AM
clubfoot
clubfoot's Avatar
Yellowssm I see you've ordered Volks, so when they come in weigh the front an back and I'll weigh my stock set later today, so we'll have some hard numbers.
Stock
Front=47.5 lbs
Rear=52 lbs
Old 03-27-06, 10:39 AM
Lets Drive
Lets Drive's Avatar
If you're worried about handling, I'd first look at a set of tires that could work on the car, and then the wheels. 18's tend to offer a wider range of options when coming to tires, but if you're worried more about straight line acceleration as opposed to lateral, just go for the lighter wheel that you like.
Old 03-27-06, 08:20 PM
federalman
federalman's Avatar
Questions:
lighter wheels will perform better, but more $$$ too.
You can never go wrong with Rays as for tire... you really pay for that you get.
go with 18"s if you want big you have to go with 20"s.
19"s tire are usually more $$$.
market for 19"s is not that competitive compared to 18" and 20"s
Old 03-27-06, 08:34 PM
yellowssm
yellowssm's Avatar
Stock
Front=47.5 lbs
Rear=52 lbs
I will weigh them when I get them but thats not gonna be for a while.
Old 03-28-06, 07:15 AM
dsdfan
dsdfan's Avatar
Default ProDrive Vs. Volk
Will be going for ProDrive G010 18x8 instead of Volk CD28NF as the ProDrive is more readily available. I hear Volk and ProDrive are of comparable quality. Am I right?
Will it compromise the car's performance and handling if I reduce the offset to as little as +38? Not only does it look better, I hear stability improves due to a wider wheelbase. Are there any negative effects of this?
Thanks!
Old 03-28-06, 11:02 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Hopefully this little piece of info can help you!!!
The Front 18x8 G-Spider Wheel/Rim weighs approx 25lbs.. alone....
Old 03-28-06, 11:14 AM
4TehNguyen
4TehNguyen's Avatar
Thanks!
i highly doubt you will see any handling improvements from a mere change in offsets
Old 03-30-06, 04:13 PM
SkydotCom
SkydotCom's Avatar
Questions:
No one really answer your question about the ISP Mode and G Spider?
Old 04-03-06, 09:54 PM
Mrbig
Mrbig's Avatar
Default ???
I was also curious what the ISP wheels weigh ?
Quick Reply: ISP Mode & G Spider as Light as Rays Volk Wheels?
