"Wind" noise near door?
Old 03-20-06, 07:29 PM
SportyStar
SportyStar's Avatar
Originally Posted by TimboIS
It's probably a result of where they put the key lock box. The windows and frames weren't meant for those to be jammed up there. With vehicles sitting on the lot, you'll likely have a detent where the box was.
Good observation. In fact, my left rear window molding had two large detents due to the key lock box. I noticed one day while washing my car, the trim was jammed way up into the frame. No luck prying it back down myself. I mentioned the problem to my salesperson, who said yeah, he's aware, and they were eventually going to be doing away with those key boxes. I don't remember hearing greater than normal wind noise while the molding was distorted. But anyway, I had to have some body work done so I had the shop fix the molding while my car was in for service. The molding's back to normal now.
Old 03-22-06, 10:39 AM
Kermee
Kermee's Avatar
I've checked the molding and haven't seen anything out of the ordinary. If I have my music even at the slightest level, I can't hear the noise anymore so I'm going to live with it for now. I think with my particular issue, it might be expecting too much from the Lexus service shop to fix because I for the life of me can't find anything physically wrong with the molding. It might be that the 2IS is so quiet that with the radio off at at 70 MPH, you're should expect some "turbulence" noise near the B-Pillar.
Cheers,
Kermee
Old 05-11-06, 11:47 AM
roymar1
roymar1's Avatar
Default wind noise on GX470
I've noticed at 50-75mph what seems to be an open rear passenger window type noise on 06 GX 470. Have checked all gaskets & seals and all appear to be ok. I wll bring it to the attention of the service dept on my first 5k check-up and hope I don't get the run around. Any tips anyone can give would be appreciated as this is my first L (former infiniti loyalist until M-45 disaster). Thanks for any advice.
Old 05-11-06, 01:05 PM
Kermee
Kermee's Avatar
I forgot about this thread.
If anyone is curious, I determined the wind noise is coming from the outside door handles.
Yes, the outside door handles. And there's nothing I can do about it other than covering it in tape. It's a known issue with some Lexus models, just not very publicized because it's really not that bad and I'm just being picky. (You can only hear it if the stereo is off).
Cheers,
Kermee
alexlude
11-04-16 02:39 PM
Jimbo2828
04-04-11 07:46 PM
ChrisM910
04-25-06 01:41 PM
YoungP08
03-17-06 10:26 AM
GS450h FTL
GX - 1st Gen (2004-2009)
12
01-29-05 06:50 AM
Quick Reply: "Wind" noise near door?
