ECT PWR button
#61
Originally Posted by jcreech
so far so good. just perfect.
#62
Originally Posted by ES3
As long as you get rid of the car before 60k miles you should be okay.. it's later on that I've been told improper break-in shows its impact.
Engine life is one of the last things you need to be concerned with unless your goal is 200k miles. A noble goal, but most cars fall apart in other areas long before the motor ever hits that mark.
#63
Originally Posted by mcfly
With all due respect, when was the last time you ever saw a motor fail in a modern car for ANY reason other than outright neglect, let alone "improper" break-in? Exactly, you haven't.
#64
I think most people that lease take good care of their car. I probably take better care than most. My S60R gets waxed by me 3 or 4 times a year and that is over the sealant and washed at least 3 times a month. Some of us take pride in the vehicle we drive whether we leased or purchased it.
I'm sure there is an exception to every rule.
#65
#67
Originally Posted by kevp913
Here yo go... behind the wheel, next to the start/stop button.
#70
Originally Posted by Foxberry
I only engage Power mode if a potential race is imminent!
#71
Today on my long drive to school i played with the power button on my GS (srry, yes i know this is an IS forum) , but does any one know if it makes a difference of when u turn it on, wheater ur at a complete standstill, cruising, or accelerating,.....
#72
#73
When I do it say with cruise control on, it doesn't downshift or anything, I believe that you need to accelerate in order for it to make a difference, after you do, it downshifts, then HOLDS the gear for much longer, in case you need power, before upshifting.
#74
#75
yes, it takes effect immediately. if youre cruising and you switch it on you can feel the gas pedal feel a little bit lighter. its a very nice feeling, as if the IS wants you to just mash the thing to the ground....
