Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
Old 01-17-14, 04:06 AM
  #946
10lexISR6
10lexISR6's Avatar
Originally Posted by Windaica
I bought the car used, it's is350 2007 with sport package. Does anyone know if it has ML?
I believe it should say Mark Levinson on the radio face just left of the right ****. If not then you probably dont.
Old 01-19-14, 01:06 AM
  #947
monsieurvo
monsieurvo's Avatar
have yet to do this mod, but before i do.... is it possible to switch to GPS to the DVD and vice versa whilst car is in motion?
Old 03-12-14, 04:27 PM
  #948
tcho82
tcho82's Avatar
I did this a few years ago, but have always been annoyed that it seems my nav does not recenter straight. Has anyone else noticed this? I never use the DVD while driving so I'm putting it back together the way it was because I actually like the option to hit speed dial while driving.
When the car is driving straight, often times, the street is not straight, It is pointed a few degrees right or left. Its sort of an OCD thing, but it annoys me enough.
Old 10-15-14, 08:41 PM
  #949
skoota500
skoota500's Avatar
sorry to add to this super long thread but, If I have a non ML and want to play video with vaistech sl2vi do I need to cut the pink and white wire? or just ground the red wire? Im just looking to watch videos in motion, nothing else really.
Old 10-16-14, 07:07 AM
  #950
skoota500
skoota500's Avatar
Anybody have or had this installed? just need some clarification.
Old 10-16-14, 12:29 PM
  #951
xerxes717
xerxes717's Avatar
This definitely happens to me, it's annoying for sure but doesn't seem to interefere with the functionality in any significant way.
Old 10-17-14, 11:25 PM
  #952
skoota500
skoota500's Avatar
Alright so I just did this mod tonight along with a SL2VI install. The nav hack was pretty simple, just followed instructions from OP. The difficult part was realizing that I don't have a red wire (parking brake) like everyone else. I had two pink wires. One was light pink, the other was a little darker pink. I was super hesitant about cutting this darker pink wire since it was supposed to be a red wire back there. But, I cut it and grounded it anyway and BOOM! video while in motion.
Old 12-09-14, 05:36 PM
  #953
Gknight1
Gknight1's Avatar
Default Need help with 2013 IS 250 dvd bypass
Not sure which wires to cut on this as it looks different from pictures.
Can someone help me with this?
Old 01-24-15, 03:42 PM
  #954
Drp2794
Drp2794's Avatar
Default After the hack getting issues
Hey guys so i did the hack and having some issues and wonder is anyone can help me
I get the lexus logo and then black screen when i hit the map button it says "external system not connected" and AC, radio nothing turns on?
Any help would be great!!!
Old 01-27-15, 12:23 AM
  #955
Mehul1456
Mehul1456's Avatar
Will this work on a 2015 Nav Unit?
Old 03-09-15, 07:20 PM
  #956
khrono
khrono's Avatar
Hello, does anyone know if this hack will work with a 2010 HS250h ML navi?
Thanks
Old 03-10-15, 05:17 PM
  #957
speeddem0n
speeddem0n's Avatar
Yes i wondered the same thing, it is very close to red but has a slight lighter tint to it.
I just did it this past weekend on my 2008 ISF with ML, along with part 2 of the hack found here...
https://www.clublexus.com/forums/is-...ng-switch.html
However when I cut my wires, I extended them to the center console and I put toggle switches on them that way I can flip switches and everything becomes normal if needed.
And since I was behind the radio/navi, I also tapped wires on the IGN and BATT wires to do the ALARM add ons as well, I will probably finish that sometime this week..
https://www.clublexus.com/forums/is-...ory-alarm.html
Thanks to the OP and all who contributed to this thread.
Old 10-10-15, 10:55 AM
  #958
2008ISF
2008ISF's Avatar
Default Looking for some advice...
Just need some advice from the electronic gurus...
Had my touchscreen/digitizer die on me a few months ago. Took the navigation apart, replaced the digitizer, all is working perfectly again. No problem
I thought it would be nice for my wife to watch DVDs while driving. So while I had everything apart, I took the red wire out from my J50 connector and ground it to the radio chassis/side frame.
Technically speaking...I grounded the red wire from the wire harness side to the chassis.
No other wires were spliced, cut, connected. No "navigation hack" performed.
My problem now is the brake light is on all the time. Obviously I did it wrong.
Do I need to...
a. ground the red wire from the actual nav headunit to the chassis (instead of the way I did it, ground the red wire from the harness to chassis)?
b. perform the rest of the navigation hack (which I am not really inclined to do) for the DVD while moving function to work?
c. or put it back to stock...
Old 12-11-15, 09:26 AM
  #959
drwafk
drwafk's Avatar
If anyone could chime in regarding the 2010 year nav system, that would be helpful.
FYI I've searched every thread, forum, and googled the hell out of this subject but no dice.
Right now my center console is torn apart and the radio is out. The wire bundles look grossly different.
Help. Thank you.
Old 12-13-15, 09:35 PM
  #960
markjustus
markjustus's Avatar
OP, can you also enter destination points? and when you ground the E brake, does your e brake light stay on?
Quick Reply: Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
