Help removing upper control arm bolt...
Old 06-19-15, 08:20 PM
jim7485
jim7485's Avatar
Default Help removing upper control arm bolt...
I am attempting to replace both rear axle half shafts... 2007 is250... stock. 220,000 miles. I am unable to remove these bolts on either side. They won't budge and there is very little room to get any leverage. I have hit them with lage quantities of PB blaster.
Would appreciate any suggestions.
Thanks
Jim
Old 06-20-15, 09:07 AM
cruzinZ
cruzinZ's Avatar
Have you tried breaking it loose with a hammer or 5 lbs sledgehammer? Sometimes a little sledge hammer can work magic in tight spots to break loose the stubborn bolt. Another thing is to add a little heat with a small torch.
Old 06-20-15, 07:15 PM
VTsuckah
VTsuckah's Avatar
Heat and a larger breaker bar should do the trick.
Old 06-20-15, 09:26 PM
Deathrow23
Deathrow23's Avatar
Impact wrench.
Old 06-20-15, 09:46 PM
Kvs_350
Kvs_350's Avatar
Heat it up and impact gun
Old 06-21-15, 04:07 AM
cruzinZ
cruzinZ's Avatar
Where was your car driven at the majority of its life on the road? Did it spend a considerable amount of time on salt roads?
Old 06-21-15, 10:26 AM
Cyanide52
Cyanide52's Avatar
My is350 was winter driven and my mechanic had to cut the bolts out and replace with new there only 3$ a piece
Old 06-23-15, 01:00 PM
Gville350
Gville350's Avatar
I don't see the heads of the bolt/nut being rounded off just yet. I'd hit it with a torch and the longest breaker bar you can get your hands on. Should be enough to do the trick.
Old 06-25-15, 10:09 AM
jim7485
jim7485's Avatar
I beat the crap out of it, no movement. Heat was a problem because of the rubber bushing. I removed the heat after smelling rubber burning. Impact wrench on the bolt did nothing. I ended up cutting it on one side and grinding down the head on the other. Then, I drilled through the bolt. More beating and it finally came out.
Old 06-25-15, 02:22 PM
Gville350
Gville350's Avatar
WOW! You went to the last resort fix; but glad you finally got it out.
Returd
Suspension and Brakes
08-15-17 06:10 PM
scott101
15
05-14-13 11:42 AM
GS4TEK
06-02-12 04:02 PM
chi123
11-26-11 09:04 AM
newgsman
12
05-24-11 10:23 AM
Quick Reply: Help removing upper control arm bolt...
