Replace Headlight or Fix Tabs
Hello all! I have a 2008 Lexus IS 350 and the driver side headlights has a broken tab. My question is: can the tabs be fixed, or do I need to replace the whole housing. It seems like a shame to replace the whole housing since the rest of it is still in great condition. Thanks in advance.
You can repair the tab if you still have the part that came off with this:
http://www.homedepot.com/p/J-B-Weld-...8277/202528473
Thats what I used on my headlight that was in a previous front-end accident.
You can always buy a small piece of ABS plastic from ebay and cut-out the tab shape using a dremel and then bond them together, a bit of work but worth the savings will only cost couple of bucks that way
jleonard71
IS F (2008-2014)
01-10-18 05:59 PM
jhong28
CL of Southern California
04-06-15 01:28 AM
