Water leaking into trunk
Hey everyone! I'm new to this forum so hello!
The trunk of my IS350 was filled with water! where the spare tire is. I drained it of course and it was not wet anywhere and I figured out it was coming from inside the metal area of the left side and traveled into the spare tire space.
The taillight on the left side's seal was not good and was pretty open compared to the very tight seal on the right taillight. (THANK GOD, the ECU is in that area)
So if I remove the taillight assembly, what do you guys recommend for sealing it up before putting the taillight back in?
Thanks!!
Thanks!!
Trunk Leakage
Thanks!!
Thanks!!
Good luck. Update us.
^Bingo! To pinpoint where the source of the leak is remove everything and jump inside with a flashlight, while having someone hose off the car in that area. Did that in the Honda hatchback; ended up coming in from the passenger side tailight gasket. So I used black silicone and sealed it up good. No problems thereafter.
E0FLK0PTR
06-22-21 12:15 AM
happy_es3
07-31-08 04:52 PM
