Seized caliper
Old 06-24-13, 05:35 AM
lexus-is2
lexus-is2's Avatar
Default Seized caliper
I've read alot about rear calipers seizing. I've had my front caliper pins seize. The first time I replaced one side at the dealership, second time i decided to free up the caliper pin and cleaning it and re-lubed it. Just wondering what part of the rear caliper is prone to seizing? is it also the caliper pin?
Old 06-24-13, 05:37 AM
B16da9
B16da9's Avatar
yup it's the pin.
Old 06-24-13, 06:19 PM
SCWB
SCWB's Avatar
Yes. Same problem front and back. If the dealer keep the pin lubricated periodically, for example lube them every oil change, we will never have pin seized problem.
Old 06-25-13, 12:57 PM
Gville350
Gville350's Avatar
Also lightly grease the outer lip of the seal that covers the sliding pin, as that is the reason why we run into these problems. The grease will hopefully create a mositure barrier between the seal and the caliper.
bbgts
Suspension and Brakes
03-23-16 06:33 AM
kkee
RX - 1st Gen (1999-2003)
08-08-10 09:09 PM
morris
10-24-06 09:14 AM
Quick Reply: Seized caliper
