What is needed to fix this body damage?
Old 02-23-13, 06:48 PM
Darion3
Darion3's Avatar
Default What is needed to fix this body damage?
The other day i was trying to park in the only available parking space at a restaurant and the person in the spot next to mine parked literally in the middle of the line. It was a tight spot but i had no other choice. Pulling into it i accidentally hit one of those yellow stick things that have no obvious purpose. Anyway It doesn't look that bad. I figured if i replace the side skirt,take off the interior door panel and pop out the dent i should be fine. Any recommendations? It's embarrassing driving something you take pride in but is all ******ed up. Anyway here are the pics.
Old 02-23-13, 09:21 PM
blklexo818
blklexo818's Avatar
a good body shop
Old 02-23-13, 10:31 PM
Darion3
Darion3's Avatar
Damn that's expensive though.
Old 02-23-13, 10:46 PM
edgeucated
edgeucated's Avatar
To be honest, that looks pretty bad. You could try to hit up a paintless dent removal guy to see if you could get the dents out, but paint is going to expensive.
Old 02-23-13, 11:54 PM
Joshohoho
Joshohoho's Avatar
Body work and paint
Old 02-24-13, 02:15 AM
SCWB
SCWB's Avatar
Absolutely a visit to a body shop. Paint Less Dent Removal is not going to help much. He might be able to pull the dent out but the paint damage can't be cured with PDR.
A quick assessment are rear door, skirt and rear fender. They are badly scratched down below clear coat and needed to be resprayed.
Old 02-24-13, 05:56 AM
TPIS350AWD
TPIS350AWD's Avatar
I'm with the other guys...that looks pretty bad. It looks like dents in the door, rear fender, and side skirt from the pictures. PDR is really only for dents where there is little to no paint damage, which doesn't seem to be the case here. Honestly, if it were me, I would have circled around the parking lot a few more times or gone to another restaurant than take a chance with a tight spot.
Old 02-24-13, 07:08 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
The paint transfer can be removed via proper detailing... but the actual body damage will obviously need a body shop.
Old 02-24-13, 07:19 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Sorry bro, that looks like a mess and might not be able to be removed by a dent remover. You could always try them first and get their opinion.
Old 02-24-13, 09:19 AM
lysis250
lysis250's Avatar
That's is a easy and cheap fix probably around $300 at a Russian body shop.
Old 02-24-13, 07:26 PM
Darion3
Darion3's Avatar
For some reason it looks horrible in the pictures. The door and fender are not messed up other than the paint and the dent in the door. It's just the side skit that is totaled. I honestly dont care about the paint or scratches. I figured a new side skirt and remove the dent and after that all i would need to do is paint. I plan on plasti dipping the car so paint Isn't an issue.
Old 02-24-13, 07:28 PM
1sWt2GS
1sWt2GS's Avatar
agreed the damage here looks pretty bad. even if you yourself tried to swap out panels, you'd have to look for panels the same color, etc. which is really hard to come by
if paint or color isnt an issue, then i'd say go ahead and get mismatched color for panels, etc.
Old 02-25-13, 01:08 AM
IS250Fsport
IS250Fsport's Avatar
cheap fix will be someone you know that has experience or works at a body shop that will do the work discounted at a garage or else where...
you can also take it to a franchise or cheaper body shop like maaco or 1day paint and body but remember you get what you pay for. It will come out pretty clean but don't expect stripping, primer, and multiple coats of paint and clear coat with a standard repair/price
and definitely don't accept any repairs from someone on the corner of the street or swap meet for 50 bucks....chance is they are working with Bondo...and will make your car look much horrible
Old 02-25-13, 12:11 PM
Hybryd40
Hybryd40's Avatar
Body shop for sure if you really like your car
Old 02-25-13, 04:18 PM
Oficilydpd
Oficilydpd's Avatar
Same thing had happened to me. I got my body repaired which hurt my wallet pretty good. So I went to OfficiallyDipped.com and got some Plasti Dip and decided to repaint my entire car myself.
Check it out:
Attached Thumbnails What is needed to fix this body damage?-my-matte-black-lexus.jpg
Quick Reply: What is needed to fix this body damage?
