Has this ever happen to your IS250
So this is my question this afternoon I went to start my car and the brake peddle was hard like if it had no power or something like that this is my first push to start car and I'm not sure if I did something wrong or was it just one of these things that sometimes happen. Has this happen to anyone else with a 2008 IS250? After I got it to start the brake went back to normal. Is it the my battery needs replacement? or is it something worst to come.
I don't think you guys understand, the brake pedal was hard when I first got into the car when I went to turn on the car it was hard so this happen sometime during the time it was just sitting their.
This happens to me in the winter time a bit where I get in the car, press the pedal but it's really stiff (normally I hop in and press the brake down all the way and start the engine) but the button won't light up until I stomp on the brake. It's normal for that to happen once in a while but not normal if it happens often. Maybe you're leaking pressure or fluid somewhere.
Most of yall I think missed whats happening to him...
Its happened to me quite a few times, not sure why and havent found a trend. But like you said, after starting the car, it returns to normal.
To reiterate: Normal day (99.9% of times), get in the car, depress brake, start car. The brake pedal moves down before starting engine. Not so normal day, i get in the car, press the brake and its rock hard, start the car and it goes to normal. Brake did not move at all prior to engine starting.
I want to say two of the times i recall, one was after the car sat for a week and another was after disconnecting the battery. As for the other handful of times, I dont recall anything special about the cases. I wouldnt worry about it though.
OP, your experience has happened to me twice. It was out of the blue and I had made no changes to the vehicle at all. It is a random thing that "should" go ahead. The first time mine did it, it really fresked me out. But I gave it a fews days and it yet away. The next time it did it, it only lasted for two starts; after that it was fine. No explaination really; phantom brake stiffness TSIB? LOL!
i got in my car and pressed the pedal and it wouldnt move before. hasnt happened to often. after a couple of times pressing it then it goes down and i can start the car. if this is what you mean it hasnt happened in a while dont know why it does though.
Thanks you guys for understanding, I called my service adviser this morning and she informed me that it's just one of those things that sometimes happen nothing to much to worry about unless its happening day after day she said I must have pushed on the pedal when I got out. I went to turn the call on today after it being off all night and it was good, Man I'm starting to realize very quickly that their are alot of bugs that our cars have. I guess I'll just add this to the list of things I have to look out for.
1. Pedal Hard
2. Carbon Build up car drops below 500rpms sometimes acts like it wants to turn off
3.
1. Pedal Hard
3.
Completely normal.
The power brake booster uses vacuum generated by the running engine. Without it, the pedal feels rock hard. Do not be alarmed. The pedal is not locked. You just have to push really really hard. This is what it is like without power brakes.
The brake booster can store a bit of vacuum for a couple of brake presses if the engine is off. I think if you shut the car off while your foot is on the brake, you will use up a bit of that reserve vacuum. Also, I don't think the booster can hold the vacuum forever so if you leave your car for a long period of time, it will slowly leak out. Cold weather seems to affect it as well.
I guess people only notice it now because this is a push button start car which REQUIRES you to press the brake before it starts. Other cars, you might rest your foot on the brake and it will be hard because there is no vacuum, but you can still turn the ignition and the engine starts generating vacuum, then the pedal will go down like normal, and you won't think anything of it.
