2010 IS250 AWD Issue
Old 08-16-12, 10:57 PM
turboflgrl
turboflgrl's Avatar
Default 2010 IS250 AWD Issue
Old 08-17-12, 04:03 AM
meis250
meis250's Avatar
It might be just the carbon buildup, good luck
You can check the brake pad thickness easily and do a visual inspection of the fluids, so it's doable. Did you replace the differential oil as well? Don't forget to check/replace the filters.
Every 20k or so it's a good idea to put a can of BG44 or Seafoam in the tank. Hope this helps
Old 08-17-12, 07:24 AM
turboflgrl
turboflgrl's Avatar
Old 08-17-12, 10:42 AM
meis250
meis250's Avatar
I had an RX350 as a loaner and i liked it, but it doesn't compare to my IS
Dealer replaced the differential oil on my car at 64k (km)/ 40k miles. I have to do it again at 128k. I think it is doable but I do not replace any oils myself because I do not like to deal with the mess...
BK44 and Seafoam are potent cleaners, used for injectors, fuel system and carbon buildup. Seafoam can be used in the oil as well right before you change your oil/ filter
http://www.seafoamsales.com/how-to-u...treatment.html
http://www.bgprod.com/products/fuelair.html
Old 08-17-12, 11:24 AM
turboflgrl
turboflgrl's Avatar
Old 08-17-12, 03:54 PM
meis250
meis250's Avatar
no problem, glad to help, and hold your ground with the dealer. It is NOT normal what you're experiencing and they should pay for the top engine cleanup
Old 08-17-12, 09:46 PM
turboflgrl
turboflgrl's Avatar
Old 08-20-12, 03:20 PM
meis250
meis250's Avatar
hey there, did you get your car back?
Old 08-20-12, 07:00 PM
turboflgrl
turboflgrl's Avatar
Old 08-21-12, 05:54 PM
meis250
meis250's Avatar
If you continue driving it it will eventually give you a misfire code. Hard to do when you need reliable transportation...good luck
BTW, since you're getting close to replacing the spark plugs, the top engine cleaning would be recommended to do right before that. It is advisable to replace the plugs and oil after using Seafoam for instance.
AndyNYC
12-16-12 05:44 PM
skytribe
06-03-11 07:01 PM
mathew115
05-07-10 06:47 PM
Quick Reply: 2010 IS250 AWD Issue
