Old 01-09-15, 03:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY: Engine Air Filter and Cabin Air Filter 2008 IS250
Old 10-14-12, 12:14 PM
neilr11
neilr11's Avatar
Thanks for the write up and photos, just changed both filters on my IS350, was easy.
Old 10-14-12, 01:55 PM
edwinjaeho
edwinjaeho's Avatar
nice write up, most japanese vehicles 06+ have the same cabin filter placement
Old 11-05-12, 09:19 AM
lynhnn
lynhnn's Avatar
I spent 10 minutes reading this and then 5 minutes doing the actual engine airfilter change. Thanks for the instruction here. What I would add to:
1. My car is newer so I don't have the clip drop problem (?)
2. I would need a vacuum handy to suck out the debris on the bottom haft of the box.
dstorm (11-07-21)
Old 02-25-13, 09:45 PM
trmills01
trmills01's Avatar
Sweet and helpful DIY directions. Big Thanks!
Old 12-29-13, 08:44 PM
Soursauce
Soursauce's Avatar
Sooo what happens if I changed my cabin air filter without referring back to this guide while doing so, did not do the important step to put the car into recirculation mode, pushed on the accordion looking cover that I saw when I opened the compartment and heard something snap? Now even when I switch back and forth between the modes the accordion cover doesn't move to reveal the air filter frame behind it. Did I break something? Is it fixable on my own or do I now have to take it to the dealer?
Old 12-29-13, 08:50 PM
0812is250W
0812is250W's Avatar
thx for the guide..
Old 01-24-14, 11:47 PM
Abnrml
Abnrml's Avatar
I realize the original post is over a year old, but I just wanted to say thanks for not only the write up, but also the pictures. I just recently bought my IS250 second hand and felt I needed to change the cabin filter for peace of mind, with your DIY instructions and photos, it was done in 5mins!
So thanks again.
Old 07-29-14, 10:15 AM
Lex_Giorgio
Lex_Giorgio's Avatar
OP thanks for the write up!!
Originally Posted by reyoasian
step 2 is VERY IMPORTANT guys! I'm one of them who made the #1 common amateur mistake when changing cabin air filter...because I don't read manual :P
Did anything get damaged or you got lucky?
Old 07-29-14, 11:26 AM
dorkacho
dorkacho's Avatar
is is350 the same way?
Old 07-29-14, 11:28 AM
4TehNguyen
4TehNguyen's Avatar
yes 350 is the same
Old 07-30-14, 06:50 AM
Malosos69
Malosos69's Avatar
Good stuff!
Old 07-30-14, 09:03 AM
Ants350
Ants350's Avatar
Originally Posted by TiLongLFC
My friend skipped this step and it ended up costing well over $1000 to repair. The part itself is not too expensive is what I heard but labor cost was the real kicker. The service tech explained to him that by not putting the car into 'Recirculate' mode and prying open the covers he damaged the computer controlled cover on the HVAC system. To repair that part of the system they need to replace it and to replace it they have to remove the dash and a bunch of other crap which takes time. Hope you have a clearer picture heh. I'm only going by what he told me and what I've read around here and other forums. Bottom line is don't forget to put it into recirculate mode.
yep I broke mine years ago not knowing! Luckily I got them to cover it under warranty after some fight . Lol
Old 08-05-14, 10:41 AM
dorkacho
dorkacho's Avatar
Old 08-14-14, 10:18 PM
waiman3
waiman3's Avatar
thanks, about order a set from sewell.
Old 09-06-14, 08:51 AM
mdk77
mdk77's Avatar
Just followed this and it worked great. Well done and thanks.
My replacement air filter from Sewell had different "ribs" than the original. It still fit ok and seems to be working but not sure if anyone else has seen this.
Quick Reply: DIY: Engine Air Filter and Cabin Air Filter 2008 IS250
