IS-F / Sport Steering ECU
Old 01-20-12, 10:31 PM
  #31
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
There are a number of ECUs in the car. The steering ECU is a separate unit from the ECM (Engine Control Module) so it will not affect shifting in any way.
Sure, they could do everything with a single powerful computer, but it would introduce single point failure scenarios Lexus does not want to consider.
So looking at the entire scope here, there appear to be many changes for this ECU. I've been told the steering on the '11 F is better - now I'd like to know if the ECU is plug and play, or did they change more stuff to make it not possible? The wife complains about how heavy the F's steering is compared to our 350. It would be nice to be able to just swap boxes and make her happy. Too bad I'd need a Techstream enabled computer to swap these out and test.
Original IS-F
89650-53040
MY 11 IS-F
89650-53041
Original ISx50
89650-53020
MY 09 ISx50
89650-53060
89650‑53061 (supercedes 89650-53060)
MY 10 ISx50
89650-53080
89650-53081
Sport ISx50
89650‑53082
I've been meaning to ask someone who owns an F how much of a difference in steering feel there is between Sport and non-Sport mode? How much of a change is there?
(Also, your part number list for the 2010 ISx50 is a bit incorrect. 89650-53020 is for All 06-08 (with or without Sport), 89650-53080/81/82 are all for 09-12 Sport, 09-12 without Sport Package is 89650-53060/61).
Jeff
Old 01-21-12, 10:46 AM
  #32
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
Steering feel isn't noticeably different between sport and regular mode. The only really noticeable difference is throttle sensitivity. It is vastly better in sport mode.
I don't have direct access to EPO, so using the internet retailers was the only way to get part numbers, and even that's not very reliable some times. You can't beat EPO for figuring out what goes with what quickly.
Old 01-21-12, 11:16 AM
  #33
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yeah I was never 100% sure because despite the manuals stating that there is a difference in steering assist, they only give a vague graph with no actual units on the axis'. I may have to try an IS F ECU at some point, I'd like a stiffer steering feel, but I will have no control of which mode it will be in, or if it will dislike the fact that it will not be receiving any information from the ECU regarding which mode to be in (Normal or Sport).
As for the difference between 08-10 and 2011, I think I only ever drove an 08 IS F, and it was years ago now, so I can't offer any insight onto what the difference between the 53040 and 53041 ECU's might be. I'd love to know though.
Jeff
Old 01-21-12, 12:32 PM
  #34
Alantjai
Alantjai's Avatar
Originally Posted by tedward88
Dunno if this matters, but I have a 06 IS250 and the PS ECU recently went out and got replaced by the dealer. Its now noticeably stiffer than before which I don't really like...
Than the ecu of mine isnt a 2008
Could you check which partnnumber they replaced?
Old 01-21-12, 12:34 PM
  #35
Alantjai
Alantjai's Avatar
I am also wondering if the 08+ ecu is compatible with 06 cars....
Old 01-21-12, 01:10 PM
  #36
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
06 and 08 have the same ECU. The ECU didn't change until 2009.
I'm not sure on the compatibility.
Jeff
Old 01-21-12, 01:55 PM
  #37
Alantjai
Alantjai's Avatar
Yeah I saw an Used ISF ECU, but they told me it is not compatible with is250, but I doubt they really tested it.
Maybe it is worth a try?
Old 01-21-12, 04:02 PM
  #38
Alantjai
Alantjai's Avatar
Original IS-F
89650-53040
MY 11 IS-F
89650-53041
Original ISx50
89650-53020
MY 09 ISx50
89650-53060
MY 10 ISx50
89650-53080
89650-53081
Sport ISx50
89650‑53082
I did not use a techstream omputer for the swap..... So you be able to swap your is350 ecu eith your isf....
Old 01-22-12, 06:38 AM
  #39
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Right, but it won't work correctly unless it is calibrated with a Techstream enabled computer.
Old 01-25-12, 01:56 PM
  #40
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Well, after reaching a deal with Alantjai, I ordered the IS F ECU, and it arrived today. I was surprised to find that the bracket on the ECU is different, though not that surprised, considering the battery is different, so it looks like I'll have to transfer the ISx50 brackets over to the IS F ECU.
ISx50 ECU:
IS F ECU:
Jeff
Old 01-25-12, 09:25 PM
  #41
Alantjai
Alantjai's Avatar
Lol
That shouldnt be a problem if only the bracket is different... But the plugs should be the same right?
We are curious about your findings After install
Old 01-25-12, 09:45 PM
  #42
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
No it's not a problem, I swapped over the bracket from the ISx50 ECU to the IS F ECU and installed it, then calibrated it and went for a drive. It's nice, I like it. I mean it's not that much less assist than the Sport ECU I already had, but it is nicer.
Going from an 06 to what I have now would probably be a pretty big jump, but from what I had to the IS F one wasn't a huge difference, but it is definitely noticeable.
I like it.
PS: PM me your address, I'll ship out my 89650-53082 ECU tomorrow.
Jeff
Old 01-26-12, 03:40 AM
  #43
Alantjai
Alantjai's Avatar
That's cool! good to hear from you!
so let me test out a newer ecu on older cars
Old 01-26-12, 01:17 PM
  #44
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
So now I'm burning to know if the revised IS F ECU will plug and play with the original. Some on the F side of the house say the steering on the '11 models is much improved.
Old 02-01-12, 07:23 PM
  #45
jgarrido
jgarrido's Avatar
Hi guys iam new here!!!
i have 2011 is 250 manual tranmission sport Package(Canada)
What difrent is this sport package???
Quick Reply: IS-F / Sport Steering ECU
