2007 IS 250 Navigation Screen is Frozen
Old 10-09-11, 10:48 AM
joekadavil
joekadavil's Avatar
Default 2007 IS 250 Navigation Screen is Frozen
new to this forum, sorry if this has been addressed. the screen in my 2007 IS 250 is frozen. it is stuck at the "press agree to the warning" box. nothing works. the screen is not responding to any touch. how can i "reset" my navigation? where is the navi disk located? i cant find it. please help.
Old 10-09-11, 10:52 AM
Sango
Sango's Avatar
Try pulling out the fuse for the NAV unit for a few minutes and plug it back in to see what it does.
The Navi disk is behind the clock however to get it out, you need to be able to use the menu's to get to the map disc option to eject. Look in your tool kit, there should be two needle like tools which lets you put the needle though the two holes in the clock on each side.
Old 10-09-11, 11:00 AM
joekadavil
joekadavil's Avatar
Default say what?
the navi disk in my 2007 Is 250 is behind the clock? wow. i would have never guessed that in a million years. thank you for the quick reply.
Old 10-09-11, 11:22 AM
Sango
Sango's Avatar
Yep, it's behind the clock panel - it just needs to be taken off.
Have a look at this PDF on page 280.
http://drivers.lexus.com/t3Portal/do...s350n/appx.pdf
In the diagram, it will show the two needle tools in there - disregard the flat screw driver, as you can work without it.
Old 10-09-11, 11:39 AM
calvin2376
calvin2376's Avatar
Welcome to the forum, but please try searching. Had you searched simply "nav screen" you would have come up with tens of threads:
https://www.clublexus.com/forums/is-...e-up-help.html
https://www.clublexus.com/forums/is-...t-working.html
Nav screen failure is a known issue on the 2IS. I do not think fiddling with the disk or and fuses will help, unfortunately. The dealership fix is to replace the nav unit for $2000+. You can call and complain to Lexus corporate and they may split the cost with you.
If you have an extended VSA or CPO warranty it's covered.
If you search CL, you'll find threads on DIY fixes like this: https://www.clublexus.com/forums/is-...e-nav-fix.html
dizzyd85
GX - 1st Gen (2004-2009)
09-19-18 01:30 PM
Mcubero
10-23-14 01:33 PM
BB6SE
04-16-12 08:00 AM
spinbreakz
02-11-10 09:01 AM
Quick Reply: 2007 IS 250 Navigation Screen is Frozen
