IS250 with ISF Wheels - Rubbing fixes?
I couldn't wait, so I installed the wheels. Here's what happened:
Nothing. The wheels fit perfectly fine. There is zero rubbing. It looks like the 1.6" drop in the front gave me enough camber to clear the larger 225/40/19 tires. In fact, it fills the fender gap better too, so it looks pretty nice. pics later this week.
iam jealous
wich offset are your rims in the front?
i think about doing the same thing
have to buy the 19inch rims
but i have the choiche to go for the ET35 or ET40 on 8.5j rims all around
i hate the fender gap to i have with the eibach pro-kit
for the european market are the front and rear the same (1.3 inch lower)
thanks for any replay
isf rims on my 250 with isf front bumper
Hello, I'm running the same set up in the front 225/40/19 and 255/35/19 in the back...the tires fit fine with very minor rubbing when the wheel is locked to the left....If you dont want to do the heat gun trick with the plastic you can use 225/35/19 in the front to eliminate the minor rubbing...when my fronts wear down...I will go with the 225/35....oh yeah the stock sensors work fine with these rims........
can you put some pictures with the wheels straight and take a picture from the front and rear?
this is the perfect match for me!!!!!!
i love it
good work
sheetmetalfab (05-15-24)
