Has anyone done seafoam?
Old 06-30-11, 01:31 PM
hazmat
hazmat's Avatar
Default Has anyone done seafoam?
Try to find a DYI for the IS and comes up empty.
Anyone know the specific process?
Thanks
Old 06-30-11, 01:41 PM
Gville350
Gville350's Avatar
Usually you just find a vacuum hose that lead to the intake manifold and let'r rip.
Had many miles on your 350? Why considering SeaFoam? Having issues?
Old 06-30-11, 01:59 PM
hazmat
hazmat's Avatar
Just over 40k, for the pass month when I starting the car a few times it takes a little more cranking than usual. My friends just did it and have couple cans extra he was telling me it did wonders on his car so I was thinking it wouldn't hurt using it.
Old 06-30-11, 03:12 PM
misterjj2u
misterjj2u's Avatar
suck the seafoam through the vacuum hose at the back of the engine, under the cover.
Then rev it up and watch the smoke fill the space!
Old 06-30-11, 03:21 PM
The1Ghost
The1Ghost's Avatar
Im at 28k and i did it to my just to do it and clean it up in the insides and everything was fine for me... Supposably thats the best stuff on the market
Old 06-30-11, 04:49 PM
KillaIS250
KillaIS250's Avatar
Forget Seafoam, get some BG44K online, that stuff is epic goodness!
Old 06-30-11, 05:10 PM
Bigrahizzl
Bigrahizzl's Avatar
what is this stuff and what are the benefits? Is it safe??
Old 06-30-11, 05:25 PM
Justin2JZ
Justin2JZ's Avatar
It basically cleans out your engine. It is safe which most people fail to realize.
Old 06-30-11, 07:35 PM
joeker
joeker's Avatar
IIRC, you should not use the vacuum line hose for seafoam on a 6 cylinder vehicle. something about it only going to 4 and not the other 2.. anyway, crank case and gas tank are still good ways to use seafoam. just remember to change your oil within 2 weeks
Old 07-01-11, 08:36 AM
jpsilvia
jpsilvia's Avatar
it wont matter as long as it enters the intake manifold..it will feed all cylinders.
If you ran seafoam in your oil for 2 weeks your motor would probably spin a bearing, have severe rod knock etc.. it thins out the oil. NEVER run seafoam in the oil...espically under any type of load.
Old 07-01-11, 08:55 AM
tenaciousF
tenaciousF's Avatar
I would never put anything into the oil that would thin it out and reduce its lubrication/protection quality. At the very least your increasing engine wear.
Old 07-01-11, 01:43 PM
hazmat
hazmat's Avatar
so the correct way is the put seafoam in the gas tank and use vaccum hose to put it in intake manifold but not the engine oil correct? I saw my friend put a little bit (less than 1/4 can) in the oil also
Old 07-01-11, 02:03 PM
UniSlayEX
UniSlayEX's Avatar
So what is the proper way to use this? or better yet, what is the most beneficial to the whole system?
Old 07-01-11, 02:51 PM
joeker
joeker's Avatar
vacuum line intake manifold and/or gas as it states on the bottle. if you do the vacuum line intake manifold, it is definitely a two man job
Old 07-02-11, 10:45 PM
Jetfire
Royale with cheese
Jetfire's Avatar
water decarbonization>seafoam. more effective and it'll save you a lot more money. seafoam will just burn up in the cylinders. water decarb will heat up and basically detonate with micro explosions that knock the carbon loose.
Quick Reply: Has anyone done seafoam?
