Old 12-16-14, 11:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DIY - Replace OEM led footwell Lights with after-market LEDS
Old 02-04-11, 09:30 AM
  #31
Imnutz4jdm
Imnutz4jdm's Avatar
im putting in purple or ultra violet if i can find that
Old 02-04-11, 02:23 PM
  #32
pfdaxe
pfdaxe's Avatar
Originally Posted by JoshIS408
^ Red looks sick
Sick bro!..how man " strip did you use?
I used one 6" 6 LED strip per side as suggested. I just sent V-LEDs an email with regards to the color. The 5000K look closer to 6000K and don't match any of their other 5000K LEDs. I'm hoping they were mis-labeled.
Old 06-13-11, 11:24 AM
  #33
CCJ22
CCJ22's Avatar
Those of you that tapped the stock LED wires under the dash... Do the new strips turn off if you turn off your interior lights with the dial on the left of the steering wheel? The same dial that dims the gauge cluster
Old 06-13-11, 12:31 PM
  #34
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
^ I believe they do. ill try again today
Old 12-05-11, 09:58 AM
  #35
aesthetics
aesthetics's Avatar
Yo, where did you guys buy that LED strip?
Old 12-16-11, 11:10 PM
  #36
Dimitri
Dimitri's Avatar
^second that!
Old 12-17-11, 12:19 AM
  #37
kumquatism
kumquatism's Avatar
There's a link in Josh's post that tells you exactly which ones he bought. In case you didn't see it, here it is...
- 2x LED Strip, 6" Works best. Got mine fromV-LEDS (Links below)
5K White, 6k White, Green, Blue, Amber Red
Remember QTY 2
Old 12-20-11, 04:10 PM
  #38
Dimitri
Dimitri's Avatar
Thanks, bro! I was reading too fast.
Old 12-20-11, 04:55 PM
  #39
Denver
Denver's Avatar
he bought his from V-Leds
Nice write up Josh. Does this work for the 2011 as well?
Old 12-20-11, 10:24 PM
  #40
NorCalIS
NorCalIS's Avatar
Great writeup! Did this in my Subaru definitely gunna do this for my is!
Old 12-21-11, 05:47 AM
  #41
DaXxJaPxX
DaXxJaPxX's Avatar
is the OEM bulb simply a 168/194 bulb that can just be changed for a better bulb?
Old 12-21-11, 12:04 PM
  #42
ISThree
ISThree's Avatar
no. the stock one is a LED assy which is not replaceable with any bulb.
Josh did it by adding a new LED strip.
Old 12-22-11, 05:10 AM
  #43
DaXxJaPxX
DaXxJaPxX's Avatar
gotcha, wasn't sure if the strip was simply used for more LEDs. ordering a pair of red ones now
Old 12-24-11, 11:48 AM
  #44
irishcharm
irishcharm's Avatar
That is true but it is replacable with any color LED. I actually disassembled the housing of the footwells, cupholder, overhead (Sunroof), gear shifter, and ashtray LEDs and replaced them all with blue aftermarket ones that I purchased at Radioshack. It took a lot of time but they retain all the oem settings for light (dim when driving and by the gauge switch, in park) and offer a subtle ambiance that the white offered, just in blue. Ill post pictures later. and its still technically OEM.
i used 6 LEDs, a few zener diodes, soder and some time.
sNotM3 (01-20-23)
Old 04-26-12, 07:08 PM
  #45
Vibes63
Vibes63's Avatar
Looks amazing
Quick Reply: DIY - Replace OEM led footwell Lights with after-market LEDS
