Warranty Question
Old 07-03-10, 09:42 AM
Dtrain500
Dtrain500's Avatar
Default Warranty Question
I recently purchased a 2006 Lexus IS250 with 60,000 miles. The car seems to be in good shape, but I'm considering the purchase of an extended warranty. The warranty I'm considering lasts 4 year and costs $1,800. There is also a $100 deductible per service. It covers everything but cosmetic and service repairs. Is a warranty a waste of money? Will I spend $1,800 in repairs over 4 years without the warranty?
Old 07-03-10, 09:48 AM
quick123
quick123's Avatar
An extended warranty can be a huge help if you aren't a DIY kind of person, or if you don't have any ties to a service facility...we were just talking about how replacing a side view mirror actuator was over $500, so a warranty could be worth it...
$1800 is on the high side of warranties, and especially with a $100 deductable...call Fidelity (1-800-327-5172) and ask them about options...we deal with them everyday and they are not a pain like other companies...
Old 07-03-10, 10:36 AM
n8236
n8236's Avatar
quick123....u say 1800 is on the high end...what is considered a good or reasonable deal? I work very far now and I drive A LOT, so the warranty could come in handy.
Old 07-03-10, 10:47 AM
CleverName
CleverName's Avatar
With a Direct Injected engine (see carbon buildup thread) You may find 1800 cheap compaired to the cost of removing the heads for cleaning.....
I just got my IS 350 and had them put a 4 year 0 ded (paid 2000 for it). on it. I learned my ML woofer (or amp) is blown, and may have a bad busing up front, so should start to see cash back soon!
Vince
Old 07-03-10, 10:49 AM
n8236
n8236's Avatar
http://www.lexusfinancial.com/consum...elected=IS_350
Is this expensive?
Old 07-03-10, 12:07 PM
quick123
quick123's Avatar
The Lexus warranty is probably the best you can get, but keep in mind that there are still items that they will not cover (always check the fine print)...$1800 with a $100 deductable is high, you can see that the Lexus one is 4 years-$50 deductable-$1800...check with Fidelity, their platinum warranty covers just about as much as Lexus and should cost less
Old 07-03-10, 12:08 PM
quick123
quick123's Avatar
Originally Posted by CleverName
With a Direct Injected engine (see carbon buildup thread) You may find 1800 cheap compaired to the cost of removing the heads for cleaning.....Vince
You don't need to remove the heads to clean out the carbon deposits...just using a good top engine cleaner should do the trick
Old 07-03-10, 12:48 PM
E6BAV8R
E6BAV8R's Avatar
Well, the main thing I think to keep in mind here is that the warranty will NOT be from Lexus. That can be a big factor in considering the type of work that will be done.
Old 07-03-10, 01:06 PM
quick123
quick123's Avatar
^^^ Don't understand this...
Old 07-03-10, 01:50 PM
axis77
axis77's Avatar
Im thinking once your vehicle hits either A.) 4 years from the date of you purchasing brand new from the lot, or B.) the car reaches 50k the factory warranty becomes invalid and you cant purchase a lexus extended warranty unless your under the factory 4 years or 50k. So for you i believe what people are saying is you can go to a third party and purchase a similar warranty for your vehicle.
But if you like you can give Troy Dietrich from Toyota of Greenfield a call. Thats where I recently purchased my Platinum 100k or 4 years $0 Deductible warranty ....
Old 07-04-10, 07:41 AM
A1Lexis
A1Lexis's Avatar
If you are looking for the Lexus Platinum warranty, check out this thread for contact info. and save some $$
https://www.clublexus.com/forums/gre...-warranty.html
ghenley
08-25-11 05:15 PM
savernus
RX - 1st Gen (1999-2003)
01-18-10 09:38 AM
litogo
GX - 1st Gen (2004-2009)
05-25-09 09:15 PM
OK LEXGO
CL of Southern California
02-25-07 10:06 AM
gokaden
09-27-06 02:52 PM
Quick Reply: Warranty Question
