Old 12-16-14, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
LED Lighting Replacement Guide (w/Pics)
Old 08-05-10, 11:48 AM
  #61
brociouz
Uber 1337 Moderator
brociouz's Avatar
Originally Posted by flektone
Brociouz
do you think you can get away with using only 2 Leds in the front dome light and have it still looking bright enough?
You could, and it would still be significantly brighter than stock. However, it's important to note that when you shut the doors to your car, the two outer bulbs/LEDs in your front dome fade out completely, leaving only the center one on (until it fades out completely later). If you only have the 2 outers, and leave out the center, there will be no light from your front dome for that period of time.
Old 08-10-10, 09:35 AM
  #62
brociouz
Uber 1337 Moderator
brociouz's Avatar
First & second posts have been updated. Now includes pictures and info on how to install the circuit board LED in the trunk light. I also tried out the circular circuit board LED, which I don't recommend because it doesn't match the color of the other LEDs in my guide. I also updated the blue LED replacement guide to reflect the release of the new high power festoon bulb for the rear dome - the direct equivalent of the one in the 6000K white guide.
Old 08-10-10, 09:38 AM
  #63
svntwosix
svntwosix's Avatar
GJ Brian, you're outdoing yourself. Maybe you should add official CL LED Expert in your sig now.
This would've been way more efficient then looking through the lighting mod thread when I first joined
Old 08-10-10, 02:01 PM
  #64
516IS
516IS's Avatar
This guide was a lot of help, thanks again.
Old 08-20-10, 09:14 AM
  #65
dojoman
dojoman's Avatar
When I changed the puddle lamps with V-LED white they seem to be kind of lose fit. When I push the LED all the way the light does not come on. I had to pull out a bit to get bulb receptacle and LED PCB lined up. Does anyone know if this will cause any problem in the future with car vibrating and hitting pot holes the connection might come lose?
Old 08-20-10, 10:11 AM
  #66
brociouz
Uber 1337 Moderator
brociouz's Avatar
^ You're welcome guys. Happy to help.
This is a known issue. You just push the LED in as far as it goes, then pull it out like 1 mm until it lights up. The connector in there is strange, but once you do this it's all good. I've hit plenty of pot holes with zero problems.
Old 08-20-10, 10:31 AM
  #67
dojoman
dojoman's Avatar
Thanks for feedback.
Old 08-20-10, 05:27 PM
  #68
AndMg
AndMg's Avatar
I cant seem to figure out how to swap out the vanity, front dome and rear dome housings. How do i remove them properly, they wont budge!
Old 08-20-10, 05:29 PM
  #69
brociouz
Uber 1337 Moderator
brociouz's Avatar
Read this then let me know if you have any questions: https://www.clublexus.com/forums/is-...ting-mods.html
Old 08-20-10, 06:05 PM
  #70
AndMg
AndMg's Avatar
It says Page not found
Old 08-20-10, 06:25 PM
  #71
brociouz
Uber 1337 Moderator
brociouz's Avatar
Link fixed, try again.
Old 08-20-10, 06:54 PM
  #72
AndMg
AndMg's Avatar
The link worked great!! i have them all changed out except the vanity. the front i dropped the whole housing grey plastic and lens the rear i just dropped the lens, so how about the vanitys?
Old 08-20-10, 07:00 PM
  #73
brociouz
Uber 1337 Moderator
brociouz's Avatar
^ Stick a flathead screwdriver between the side of the plastic and the felt of the roof and pry it out. The plastic just pops out. One side pops out easier than the other, I forget which though... Maybe the outer side closer to the door.
Old 08-20-10, 07:40 PM
  #74
AndMg
AndMg's Avatar
Thank You!! You are a true ASSET to this site!
BTW the Vanity's release from the driver or left side
Old 08-20-10, 07:42 PM
  #75
brociouz
Uber 1337 Moderator
brociouz's Avatar
^ You're welcome. Enjoy the LEDs!
Quick Reply: LED Lighting Replacement Guide (w/Pics)
