Old 12-16-14, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
LED Lighting Replacement Guide (w/Pics)
Old 10-22-14, 07:47 PM
  #676
istarzan
istarzan's Avatar
Any pics? 10 char
Old 10-25-14, 06:30 PM
  #677
valeoray
valeoray's Avatar
Originally Posted by 5nX37
So I decided to not go HID but instead went with LED headlight bulbs to replace my stock halogens. This is more of a feedback from my experience as I haven't seen any info on how LED headlight bulbs perform. I'm referring to the newer designed CREE type LED with cooling fins and driver relay harness designed for headlight application not the older design with the SMD clustering all around the bulb..
The bulbs appear to be in high quality fit and finish. Installation was easy and the wiring harness all fit right inside the headlight housing. No bulky ballast or drilling needed.
How did you get the hard back plastic cap to fit back on as the LED has the bulky cooling fins that take up so much space?
Old 10-26-14, 10:14 PM
  #678
5nX37
5nX37's Avatar
If you're referring to the dust cover, there was no problem with that at all. There's enough clearance for the bulky bulb to fit and the dust cover to attach back on without issues.
Old 02-01-15, 04:08 PM
  #679
Golfer2000
Golfer2000's Avatar
Most links are dead. Updates?
Old 02-03-15, 07:58 PM
  #680
jessmessin
jessmessin's Avatar
Default Nice
Nice. definitely needed this. thanks for the post!
Old 02-28-15, 10:48 AM
  #681
subiepunk
subiepunk's Avatar
updates for the trunk light? Link is dead
Old 03-02-15, 11:06 AM
  #682
Nixcision
Nixcision's Avatar
yup I'm also looking for the trunk light ^^^
Old 05-07-15, 09:43 AM
  #683
dyongg
dyongg's Avatar
Just had a quick question:
Which are the front dome lights? I'm looking to change the yellow lights that turn on when doors are opened.
Old 05-23-15, 10:15 AM
  #684
IS250LALO
IS250LALO's Avatar
Nice Job, I like this interior upgrade!
Old 06-02-15, 01:08 PM
  #685
pattatted4
pattatted4's Avatar
Thanks! Install begins tonight!!!
Old 06-04-15, 05:28 PM
  #686
Knarf916
Knarf916's Avatar
Not too crazy on interior lighting but i may change that soon.
Old 06-07-15, 07:44 AM
  #687
M4rk
M4rk's Avatar
Excellent guide, thank you.
Just finished my '14 IS-F in 5000K. Everything was spot on, except my front dome assy. actually took 3 bulbs, versus only 2 reported in this guide. It's a Canadian car FWIW, no SOS button. Thankfully I had an extra 360-style bulb in 5000K.
LEDs I ordered:
Dome x2: http://www.vleds.com/shop-bulb-numbe...58-1-pair.html
Visor x2, Door x2, Puddle Lamp x2: http://www.vleds.com/shop-bulb-numbe.../5k-4-hpf.html
Rear Dome x2: http://www.vleds.com/shop-bulb-numbe...75-de3175.html
Trunk: http://www.vleds.com/shop-bulb-numbe...29mm-3022.html
Reverse: N/a, already had some from my previous car
This setup is incredibly bright, perhaps moreso than I wanted. No complaints on the puddle lamps being so bright though, it's a priceless feature. Install was very easy and straightforward, except removal of side mirror glass, which made me sweat.
The LEDs
Before
After
Old 06-07-15, 10:50 AM
  #688
oldglo
oldglo's Avatar
Default Blue Vanity Mirror Light [Installed]
Light Model:
Vanity Mirror (1 slot for each mirror, 2 slots total): V-LEDS BLUE 4 LED 2 WATT HP FLANK BULBS 194 168 158 | 1 PAIR (flank style)
Link to buy:
http://www.vleds.com/blue-4-hpf.html
Old 01-25-17, 03:48 AM
  #689
Jz39
Jz39's Avatar
Anyone know the part number for the clear lenses for the door lights? The original link in this thread went to Sewell which no longer exists.
I just bought the 8000k set from precisionled. Looking forward to the upgrade.
Old 01-25-17, 05:19 AM
  #690
istarzan
istarzan's Avatar
These are much much brighter with built in clear lenses. But it's 7000K.
http://store.ijdmtoy.com/Lexus-IS-ES...s-p/75-008.htm
http://store.ijdmtoy.com/Lexus-IS-ES...s-p/75-010.htm
Quick Reply: LED Lighting Replacement Guide (w/Pics)
