Will those wheels fit? START HERE.
Old 01-10-15, 11:41 AM
  #5116
CMACE23
CMACE23's Avatar
Good day everyone, I'll start with my setup in case anyone in the future is going for the same setup. I have a IS250 with 18x8.5 +35 (225/40/18) 18x9.5 +22 (245/40/18) Varrstoen ES2 slight fender roll in the rear lowered about 24.5" from top of the fender/quarter arch to the ground on Megan EZ coils. Very very little rubbing in the rear none up front(no fender mods). Although the front is kinda weak and could use a spacer or different offset.
My question is however would my front wheel setup clear IS350 brakes?
Thanks in advance for any info
Old 01-12-15, 10:23 AM
  #5117
DaXxJaPxX
DaXxJaPxX's Avatar
looking to put some Enkei T6S' on, 18x9.5 +30 on all corners. Will I need a roll in the front? If I do the front, what tire size should I run?
Old 01-27-15, 02:11 AM
  #5118
shomci
shomci's Avatar
Default buddyclub 18/7,5 - would it fit?
hi guys,
i am thinking of replacing my wheels... unfortunately they are not stock, aftermarket wheels came with the car when i bought it used.
i have a chance to get a set of buddyclub rims.
18x7,5 (all four wheels)
ET42
73.1 hubcenter - i assume i will need a converter ring to 60.1?
and the tyres would be 225/40R18 in all rims, in the rear and the front.
car: 2007 RWD Lexus IS 250
what do you think, would this config ok for my car?
wouldn't it cause trouble for me in stability etc?
does anybody have a list of accepted tyre/alloy ranges?
i know the original wheels are 8" in the front and 8,5" in the rear and with 225/40 and 255/40 tyres... it is almost impossible to get factory wheels in my country and i like the buddyclub more..
thanks
Old 01-27-15, 05:01 PM
  #5119
6SpeedIS
6SpeedIS's Avatar
Has any fit a 20x10.5 +25 under the front if an ISx50? Trying to see what I can get to fit without modifying the fenders too much
Old 01-30-15, 10:48 PM
  #5120
langjaykev
langjaykev's Avatar
Tire question,
I am now running a 10.5 +32 or +34 (i forgot) on tire sizes of 245/35/19.
I am lowered about 2 to 3 fingers from wheel lip to rear fender. I want to throw on 255/35/19s instead.
I have stock camber arms, so my "stock" cambered from being lowered is roughly 2.5-2.8.
Will those 255s fit?
Oo also I am coming from federals, I want to switch to Hankook v12s. 0 rubbing issues with the ferderals at 245s
Old 02-05-15, 04:45 PM
  #5121
janis300
janis300's Avatar
Will these wheels fit on my 07 IS250 - vessel cv7
Front Wheels
Offset: +20
Tire size: 245/35/20
Rear Wheels
Offset: +25
Tire size: 275/30/20
Old 02-18-15, 08:37 AM
  #5122
Lowlex350
Lowlex350's Avatar
Default Offset??
What's up guys!
I've been looking to get a set of Vordoven Forme 9 (Work Emotion CR reps) wheels but questioning if the offset will fit on my 07 IS350 without a lot of work.
18x9.5 +12 Fr
18x10.5 +15 rr
Plan on running 215/35 fr n 245/35 rear. I'm lowered on Megan EZ coils with fenders rolled and bumper tab relocated. What other mods would be necessary for it to fit? Thanks in advance!
Old 02-20-15, 10:02 AM
  #5123
is25019
is25019's Avatar
hey I have a 2011 is250 rwd factory setup is front-225/45/17- 17*8, +45mm rear-245/45/17- 17*8, +45mm rear---
can i run 17*8.25 with +36mm front, and rear- 17*9.25 +36mm using same tires or no? (XXR 550) new to the rim/tire game so any help would be appreciated!!!
Old 02-22-15, 07:02 PM
  #5124
is25019
is25019's Avatar
have a 2011 is250 rwd, looking at setup of 18*9 rims, can i run 235 in front, and 255 or 245 in back?
Old 02-23-15, 09:53 AM
  #5125
DocFreud
DocFreud's Avatar
today i got a new winter setup, coz i hate ugly *** wheel season..
rims are RH nbu race (german manufacturer)
18x8.5 offset 45 ,
tires 225/40 pirelli sottozero 3
my car is lowered with kw variant 3 coilovers + stiffer springs.
pic:
to achieve a more aggressive look i bought spacers. back: 30mm per side , front: 25mm per side .
the front pokes now 5mm more then my summer setup (19x9 225/35 offset 36)
so new offset 20 in the front, 15 in the back. the back is no problem but the front is rubbing like hell. at the bumper tab of course.
i knew I could encounter some problems, because in the past 2 years i did a lot of research in wheel setups and i read this complete thread.
well, in the aggressive wheel thread 19x 8.5/9 offset 20ish is very common but I just don't get it how people can drive like these. more stretch and rolling the fenders would help yes. but it just won't help to clear enough space. a single turn with a pothole or a bump will end in serious bacon fender.
here is a pic with a quarter wheel turn, which is not enough for most corners
so, finally my question: am i doing it wrong or is the pain tolerance a lot bigger from most of the guys here?
Old 02-23-15, 07:26 PM
  #5126
ltse123
ltse123's Avatar
looking to buy some varrstoen es3 19x9.5 19x10.5 +22 or zedd sl5 19x9.5+22 19x11+25. I have sport package on my 07 with factory fsport suspension and not looking to slam the car anytime soon. When i got my alignment recently the rear camber is at -2.
My questions are
1) will these clear the 350s calipers? the research ive done suggests the es2 wont clear what about the es3. Ive found nothing on the zedd sl5s
2) how far will 19x11 in the rear poke out? I dont mind rolling and pulling fenders and stretching tires just dont want them to look ridiculous
Old 02-26-15, 11:54 PM
  #5127
Nchang96
Nchang96's Avatar
Default Will these fit?
I have an is250 and I'm wondering if these will fit. Im kinda a noob.
front- 19 x 9.5 +12
rear- 19 X 10.5 +22
Euro Tek UO5 Wheels
Thanks in advance
Old 03-04-15, 11:52 AM
  #5128
SoSickG35
SoSickG35's Avatar
19x9+35 19x10.5+36 fitment is good for me you guys but im looking to stretch my tires... what size should i go with?!?!? any help please
Old 03-05-15, 11:25 AM
  #5129
SoSickG35
SoSickG35's Avatar
bumppppppppp
Old 03-09-15, 07:50 PM
  #5130
Alwaysgolf
Alwaysgolf's Avatar
Originally Posted by nfordhk
Can someone give me advice on:
2011 IS350 FSport
19x10 Offset +2 3.5" Lip
19x11 Offset +9 4.5" Lip
I have an Fsport big brake kit.
thats really aggressive offsets ...
better stretch the **** out those and run alot of camber lol
and pull your fenders
Quick Reply: Will those wheels fit? START HERE.
