Will those wheels fit? START HERE.
Old 08-11-14, 10:58 AM
  #5071
Alwaysgolf
Alwaysgolf's Avatar
Originally Posted by dlexustep
Was wondering what I have to do to fit 18x10.5 +15 in the rear on my is250 rwd with Megan racing coils
It all depends on how low you go.
1. Look into trimming or rolling your fenders
2. To make sure your rims clear , id test fit and determine how stretch you should go. Personally with 18" rims I like going with the 40 profile. Something like 235/40r18 or 245/40r18 ( will give you a nice stretch look ) .
Old 08-11-14, 12:23 PM
  #5072
lysis250
lysis250's Avatar
Originally Posted by Alwaysgolf
No way xD . Highly doubt that
Please do your search, here is a thread that took me 30 seconds to find hopefully that changes your thinking.
https://www.clublexus.com/forums/is-...tml?styleid=14
Old 08-11-14, 01:22 PM
  #5073
quick123
quick123's Avatar
Haven't been on this thread in a while...so many questions without enough detail to give an accurate answer. It would be nice if those wanting to help got complete questions about possible setups. Here are a couple basic things one would need to provide useful information.
- wheel size and offset (this is usually not an issue, but width/diameter/offset front and back)
- how low you want to ride (spring drop, coils and how much gap you want to fill, etc)
- look or style you are trying to achieve (flush, poke, tuck, etc)
- amount of tire stretch (none, minor, etc)
- willing to do fender mods (none, roll, pull, shave, bumper tab, etc)
- camber preference (no camber, natural negative camber, max negative camber, etc)
Without getting these basics, you are pretty much asking hypothetical questions that will get in return hypothetical answers. If you really want some "expert" advise, you need to have your setup planned out and then ask an "expert" question.
No hate here, just love and a want to help everyone I can...but like I tell customers at work, sometimes you need to help me help you.
Old 08-13-14, 09:11 PM
  #5074
FlipSquad
FlipSquad's Avatar
Originally Posted by sm1ke
That's what the search function is for. Search the thread for the wheel fitment you have questions about, IE. "18x9 +15". If nothing comes up, search for "18x9" and you'll get hits with offsets close to +15, then just use common knowledge to estimate.
Want to make sure rolling diameter is in check?
http://www.1010tires.com/Tools/Tire-Size-Calculator
Want to compare your current setup to your new setup?
http://www.willtheyfit.com/
Using all of the above, anyone should be able to figure out for themselves what will or will not fit in terms of stance. As far as the work required to achieve that stance.. Well, just prepare for the worst. Roll fenders, trim wheel liners, be prepared to relocate bumper tabs, get adjustable camber arms and finally, get a four-wheel alignment.
How do you think I found this thread? lol but thanks for the links. I was only pointing out this thread is 80% jacked with people asking questions with little to no answers as to what theyre looking for. But I do realize that a lot of factors come into play so hopefully those links you posted will help others.
Old 08-14-14, 07:59 AM
  #5075
sm1ke
sm1ke's Avatar
Lol no I meant search within the thread to narrow down the posts you have to look through. You can check the "Pic of your 2IS" thread too, usually people post their cars and someone always has questions about their stance. Good luck!
Old 08-18-14, 11:48 AM
  #5076
Annimossit
Annimossit's Avatar
Default Need some input
2006 is250
XXR 527
18x8.75 20mm 225/40/18
18x9.75 20mm 255/40/18
I am on stock suspension, will this fit? I plant to do a mild Eibach pro kit drop later on.
Old 08-28-14, 05:28 PM
  #5077
Annimossit
Annimossit's Avatar
Originally Posted by Annimossit
2006 is250
XXR 527
Bump anyone? I want to be sure before i take my tires off and purchase these wheels.
Thanks!
Old 09-01-14, 06:27 PM
  #5078
NR1DAD
NR1DAD's Avatar
https://www.clublexus.com/forums/is-second-generation/755361-got-wheels-that-i-want-to-fit-my-car-wheel-guys-help.html#post8694441
Need help
Old 09-01-14, 06:49 PM
  #5079
06350F
06350F's Avatar
06 is350 rear fenders rolled - tien springs
No camber kits and not willing to purchase
18x 9.5 + 15 front
18x10.5 +15 rear
Flush,poke, or mad max?
Old 09-02-14, 04:37 AM
  #5080
laobo979
laobo979's Avatar
18x 9.5 + 15 front
18x10.5 +15 rear
I suggest you buy something eles then. When running aggressive setup you not wanting to buy then you can rub all day.
Old 09-02-14, 06:38 AM
  #5081
06350F
06350F's Avatar
I'm not worried about rubs as much as them looking funky. Flush is what I'm trying for. I can get the wheels dirt cheap. I just don't want spacers at all or have that mad max look with the wheels sticking out
Old 09-16-14, 11:09 AM
  #5082
RapidFire
RapidFire's Avatar
This isn't a will these wheels fit question but figured this was a good spot for my question. If not apologies!
Just bought this within the last few months it's a 2010 IS250. I love the look of so many of your IS's in the picture thread here but don't have the budget or abilities to do 95% of the stuff here. I really like the look of the darker wheels is that something I'd be able to do without buying new wheels (I've seen kits to darken them for instance that looked pretty easily DIY)? Any idea what my wheels are made of and would that matter with the product I get if it is possible to do myself?
I was wanting to do that and get the windows tinted and I think that would be a great start and not too expensive.
Thanks for any help!
Old 09-16-14, 06:57 PM
  #5083
BigBawss
BigBawss's Avatar
I just bought my wheels couple weeks ago and just need some pro tips about what tire size should I get or do i have to purchase a camber kitand if there's any adjustments on the camber where should i set it and I pretty sure I'm gonna need some fender modification on this one. currently lowered right now with at least 2 finger front and a lil -finger rear. Pic would be really great too. thanks.
I got a F19x9.5 +22 & R19x11 +25. I was thinking of gettin a 225/35/19 on the front and 255/35/19 on the rear with Continental Extreme DW.
Old 09-19-14, 11:16 PM
  #5084
rayac88
rayac88's Avatar
Default 20x11 stretch
has anyone stretched a 255/30 on a 20x11? i know with the offset im running i will need a good stretch. i do need some kind of stability with the bead as i take my car to the drag strip. the tires are toyo all seasons. pretty soft tires.
Old 09-23-14, 03:51 PM
  #5085
Litcroco
Litcroco's Avatar
Hi CL! I found this set of rim that is 18x8 +47 & 18x9 +47 and wonder if they will fit my awd IS250. What's the best tires size I should get.
Quick Reply: Will those wheels fit? START HERE.
