Will those wheels fit? START HERE.
#4936
need some advice for this setup
im now drop with tein spring but just bought coilovers to go lower and want to know if ill have roll to fenders or stretch tires
here is the wheel and tires speca
Front:
19x8.5 offset 35
tire 225/35/19
rear :
19x9.5 offset 38
tire 265/30/19
want a 2 inch drop front and rear
thanks
Front:
19x8.5 offset 35
tire 225/35/19
rear :
19x9.5 offset 38
tire 265/30/19
thanks
#4939
Ok got wheels in my living room need to buy tires..
Xxr530
18x8.75 20mm front
18x9.75 20mm rear
Currently lowered on Megan coilovers.running stock 17 is250 awd wheels with 2finger gap all around.what size tires would I need for a clean flush look and what kind of rolling and pulling will be needed.not looking for a big poke,the closer to flush the better.and yes my car is awd
Xxr530
18x8.75 20mm front
18x9.75 20mm rear
as for fender mods , with this set up i would just trim the fenders ( personally I prefer trimming over rolling if I had a choice between the two lol )
#4940
Looking to get a set of wheels:
F: 18x8 +30
R: 18x9 +25
Stock height and stock fenders. Might lower a bit later.
Would this be flush with the fenders? I did some calculations and it seems to be pretty close but it would be great to get some feedback from you guys.
Thanks
F: 18x8 +30
R: 18x9 +25
Thanks
#4941
235/35 - rears
#4942
can someone help me, and let me know if these wheels will fit my 09 is350? thanks for the help
Wheel Diameter 19" 19"
Wheel Width 8.5" 10"
Color Platinum Platinum
Bolt Pattern 5-100/5-114.3 5-114.3/5-120
Offset +15mm +35mm
Lip Size 2.00" 3.00"
Backspacing 5.34" 6.88"
Centerbore 73.1mm 73.1mm
Offset +15mm +35mm
#4944
Looking at some Avant Garde M310.
Front: 18x8.5 +35MM with 225/40/18
Rear: 18x9.5 +40MM with 255/40/18.
Will this be flush with the fenders or will they be sticking out. I am going for a flush wheel set up. I am currently at stock height and coilovers are on the list.
#4945
Hey everyone. Need some help.
Looking at a set of Advan RS
18" 8.5 all around
+29 offset
Will this fit on a 2011 is350 AWD with no fender work and stock height? may consider fsport springs in the future.
Also will it be relatively flush?
TIA
18" 8.5 all around
+29 offset
TIA
#4946
Hey everyone. Need so"me help.
Fronts won't be flush (will stick inside once dropped), no fendor work required unless lowering more than 2"
Rear close to flush, may rub a bit due to the tyre widths depending how much you drop it with coilovers. Would work with a roll.
18" 8.5 all around
+29 offset
TIA
18" 8.5 all around
+29 offset
TIA
#4947
Can someone please help me decide on tire sizes and will this fit on a 2008 IS350?
Also I'm on Airrex, rear's are cut, I have all adjustable camber arms.
F 18X9+25mm 5X114.3
R 18X10+20mm 5X114.3
Please and thank you.
F 18X9+25mm 5X114.3
#4948
Hi,
I'm looking at getting some adapters in order to fit my friend's HRE wheels from his BMW (5x120 bolt pattern)
I was wondering what's the minimum size adapters that would clear the stock studs?
The wheels specs are:
F: 19 x 8.5 ET 30mm
R: 19 x 10 ET 28mm
My fenders are rolled and my current wheels are:
F: 19 x 8.5 ET 25mm
R: 19 x 9.5 ET 30mm
Do you think it's possible to fit his wheels with adapters?
Thanks
F: 19 x 8.5 ET 30mm
R: 19 x 10 ET 28mm
F: 19 x 8.5 ET 25mm
R: 19 x 9.5 ET 30mm
Thanks
#4949
will these fit
hey guys
wondering what tires will fit a 2007 IS250 RWD lowered on eibachs but going to coils
5x114.3 (CB: 73.1)
Front: 19”x8.5” – ET: 35
Rear: 19”x9.5” – ET: 40
would 225/35/19 fronts
and 265/30/19 rears?
5x114.3 (CB: 73.1)
#4950
Hello everyone
thanks in advance for taking time to answer my question.
i have a set of rims that are 18x8.5 front +4.5mm offset
and rear set is 18x9 in the back +5.25 offset
my tires currently are 255/40r18
and rear set is 275/40r18
please let me know if you know that they will fit. and if anyone has fitted 255's in the front
and 275's in the back.
thanks guys for your responses
Car is Lexus IS350
Car is Lexus IS350
