Will those wheels fit? START HERE.
Old 03-03-13, 09:47 PM
  #4336
projectdna
projectdna's Avatar
Originally Posted by Scless
18x9.0 5x114.3 30 Offset all around Rota G-Force Concave Rims XXR
Will They fit without modification? I'm at stock AWD height now.
Anyone?
getting close. either you run semi-stretch-size tires, or you go with fender work to be safe. you'll need higher offsets + semi-stretch tires.
there is a thread for AWD fitment if you need a definitive answer. search is your best friend.
Old 03-03-13, 10:31 PM
  #4337
RVCAis250
RVCAis250's Avatar
Originally Posted by SlapnUup
Well im going with the 40's since i have them on the stocks. If i gotta get another size i will but i really wanna try to keep that tire size. As far as ride height i would say i have a finger gap all around. So a roll all around? and shave the tabs and I should be good?
So with a finger gap, does that mean you are on springs?
I thought you were going lower. You should be fine with those 40's with those specs and drop. And at that height you shouldn't have to relocate/shave the bumper tabs. So actually just a roll all the way around would be sufficient.
But just when you do get new tires. I'd get 235/35 in the front. Until then you'll be good with your stock tires.
Old 03-04-13, 05:35 AM
  #4338
Jman8108
Jman8108's Avatar
Alright fitment gurus before my wheels arrive let me know what I can expect... I went 19x8.5 +30 up front and will be running a very mild stretch with a 215/35/19. I'm fairly low on Megan EZ's and will be just barely tucking tire up front. Planning on remolding the fender liners but my question is will I need to roll the fenders/relocate the tabs? Was hoping to get away without it since I'm running the 215s.
Old 03-04-13, 06:32 AM
  #4339
Scless
Scless's Avatar
Thank you I'll ask in that thread
Old 03-04-13, 09:12 AM
  #4340
Galvez
Galvez's Avatar
Well I'm on Megan coils and depending how it looks Ill either have the ride height the same or just close the gap all around. How about the fender liner? Should I take them off?
Old 03-04-13, 09:42 AM
  #4341
projectdna
projectdna's Avatar
doesn't matter, since they'll just be hanging there after your fenders are rolled, and won't really go anywhere. you'll probably have to be creative with your zip-ties to hold them up.
Old 03-04-13, 05:49 PM
  #4342
yoitskenn
yoitskenn's Avatar
18x9 +30 all around
265/35 rear
235/35 front
Do I need fender mod? Roll?
Old 03-05-13, 01:10 PM
  #4343
aly250
aly250's Avatar
Im looking to buy a set of Drag Dr-31s
(F) 18x8 +35, +38
(R) 18x9 + 15, +28,+38
what tires would be best to run, and would I be flush?
Would I have any rubbing issues?
Old 03-05-13, 01:25 PM
  #4344
Palmiholm
Palmiholm's Avatar
Post 19" Genesis wheels (Iceland)
19x8.5 +35 255/35 rear
19x8 +35 225/35 front
..thinking about Michelin Pilot Super Sport
I have OEM ride height.
Thank you
Old 03-06-13, 11:15 AM
  #4345
Eazy350
Eazy350's Avatar
19x8.5 + 32 235/35/19
19x10 + 38 265/30/19
Suspension H&R
I'm in ok with no fender mods?
Old 03-06-13, 11:31 AM
  #4346
projectdna
projectdna's Avatar
Originally Posted by yoitskenn
18x9 +30 all around
265/35 rear
235/35 front
beefy tires for the wheel width. may need it in the front, may not need it in the rear.
btw, why run square wheel sizes but staggered tire sizes? unless your 2is is AWD...
(F) 18x8 +35, +38
given your listed wheel widths and avaiable offsets, to avoid rubbing issues, go w/ +38 all around.
you may not be as flush, but that's due to the available offsets.
Thank you
great choice of tires - i have a full set of them and swear by them in spite of their cost.
your proposed set-up will not need fender modifications.
Suspension H&R
235/35-19 in the front + 19x8.5 +32 is pushing it. i'd go w/ 225/35-19 for clearance purposes.
i doubt you'll need fender modifications in the rear.
problem w/ those front/rear sizes is that you'll increase the amount of understeer given that the front will have the same treadwidth while the rear is one size wider. how much you feel it will depend on how sensitive you are to driving/vehicle dynamics, but it's something to consider.
Old 03-06-13, 12:06 PM
  #4347
Palmiholm
Palmiholm's Avatar
Post
Thank you, good to know about the tires
Do you think the tire wheel stance would look good with these specs wheel&tires?
I mean would they stick out and look mean, give the car a wide stance ?
maybe 225 is too narrow ?
Old 03-06-13, 12:42 PM
  #4348
sploosh
sploosh's Avatar
Bbs ch
19x8.5 +20
19x10.5 +20
Would these fit on a is350? Stock height. What is the widest tire I can fit on this set up?
Old 03-06-13, 01:05 PM
  #4349
projectdna
projectdna's Avatar
for comparison, OEM 18's run 225/40-18 and 255/40-18.
so to answer your question, no, they won't stick out, but they will have a slightly more aggressive stance than OEM 18's. and no, 225 won't be too narrow up front.
Originally Posted by sploosh
Bbs ch
19x8.5 +20
19x10.5 +20
yes, but you will need fender modifications in all four corners.
215/35-19 + 245/35-19. anything wider will need a significant fender pull.
Old 03-06-13, 01:17 PM
  #4350
sploosh
sploosh's Avatar
[/QUOTE]
215/35-19 + 245/35-19. anything wider will need a significant fender pull.[/QUOTE]
That would require fender rolling?
What are your thoughts on this spec
work vsxx
19x9.5 +29 235/30/19
19x10.5 +29 295/30/19
Which set up would match my cars better? What would be required to run this set up?
THanks for your help
Quick Reply: Will those wheels fit? START HERE.
