Will those wheels fit? START HERE.
Old 10-29-08, 12:17 AM
  #376
Lilflip#2
Lilflip#2's Avatar
My car rubs the same (maybe just a tad bit more) since i lowered it with Tein S Techs. I honestly don't mind the little rubbing. It's not super annoying and I would rather ride with 35 series tires up front than 30's. Just my .02.
Old 10-29-08, 07:27 AM
  #377
datplayaz
datplayaz's Avatar
Default Offset?
Hello everyone, i'm new here and i had a question about the offset for a IS350, what is the lowest offset i can fit on there? I want a really aggressive wheel set up... I have some 19x8.5 +43 Volk TE37 from my last car that i tried fitting on the IS... but it's not aggressive enough.
Old 10-29-08, 07:31 AM
  #378
datplayaz
datplayaz's Avatar
been doing some searching and it looks like the lowest i can go is +35 is that correct?
Old 10-29-08, 07:34 AM
  #379
javyLSU
2IS OG
javyLSU's Avatar
This is where you need to start looking.
Javier
Old 10-29-08, 07:37 AM
  #380
datplayaz
datplayaz's Avatar
thank you for pointing in the right direction
Old 10-29-08, 07:44 AM
  #381
ChrISF
ChrISF's Avatar
with 19x9.5 the lowest you can go is around +22. if you're running wider in the back, then 19x9.5 +35 would work great.
unless you plan to mod your fenders(i.e. roll them) then you can fit and 11" back there. LOL
Old 10-29-08, 02:50 PM
  #382
iSuxeL
iSuxeL's Avatar
I know for a fact you can fit 19x8.5 & 19x9.5 with a +22offset front and back.
Old 10-29-08, 03:34 PM
  #383
ChrISF
ChrISF's Avatar
oops sry, edited my post >.<
Old 10-29-08, 03:36 PM
  #384
javyLSU
2IS OG
javyLSU's Avatar
This requires some modification if you actually plan on using tires with those wheels (assuming the usual drop).
Javier
Old 10-29-08, 03:59 PM
  #385
Gus738
Gus738's Avatar
new to this too ... whats a postive off set? and why have the rear wider then the front?
Old 10-29-08, 04:19 PM
  #386
llamaboiz
llamaboiz's Avatar
*IMPORTANT NOTE*
There is a major darkside to running 'nice' offsets, something that has never really been mentioned by all of us... IF you ever drive upon a road that is being repaired/recently filled in potholes you WILL end up with road tar freckles on the side of your car... to keep your car in 'show' condition you will have to frequently use a clay bar. It's a PITA
Old 10-29-08, 06:44 PM
  #387
Slappy_
Slappy_'s Avatar
I did a test fit with a 19x9.5 +30 in the front of mine and honestly could have went more aggressive. Granted I'm only on Eibachs and didn't set the car down(coilovers), but if I was it would have only sunk in more. I'm looking more towards a 19x9.5 +20 in the front and a 19x10 +20 in the rear with coilovers.
Here's a couple pics.....
Old 10-29-08, 07:32 PM
  #388
MrMark
MrMark's Avatar
I'm running 19x9 +22 and 19x10 +22 with rolled fenders.
Old 10-30-08, 05:01 AM
  #389
datplayaz
datplayaz's Avatar
are you drop on anything?
Old 10-30-08, 07:05 AM
  #390
MrMark
MrMark's Avatar
2" drop on Road Magnet prototype springs for the AWD....
Quick Reply: Will those wheels fit? START HERE.
