AGGRESSIVE ISX50 wheel thread
Since were on the subject I was wondering when on turning does the front wheel rub against the plastic lining? I was test fitting my rims 19x8.5 with 245 tires and noticed that when turning it'll rub the plastic lining.
On my car with 20's, it rubbed a little bit on the front. I don't know if it even caused any noise, I just noticed that there were rub marks there. But on the rear is where the big problem is. It wore a hole back there on both sides. Basically where your arrow is.
Anyone can post some specs?????
I'm looking to run a more aggressive set up soon.
Thinking
18x9 +25ish front
18x10 +25ish rear
Lowered on f-sport springs for now
What tire size do you recommend? Will melting the front liners and rolling the rears be good enough? Or will i have to pull the rears?
What are your guys running??? specs????
Thinking
18x9 +25ish front
18x10 +25ish rear
