DIY: camera mount for is350
Old 05-08-08, 09:49 AM
combfilter
combfilter's Avatar
Default DIY: camera mount for is350
OK so I am doing another track day this saturday and wanted to record it. I got my idea from this website, but realized their method would be dangerous if the car rolled, and that the tech/inspection probably would not ok that.
seen here:
http://blog.makezine.com/archive/200...camcorder.html
So I figured the safest way to do it, is to mount to the back seat head rest. This way I could have support from both sides. and nothing sticking out ready to stab me in the brain.
1. go to hardware store and purchase some of that square aluminum pole like material.
2. Cut it the length of your rear head rest, leaving a little room on each side
3. drill a 1/4 in hole in the middle (or whever you want to mount the camera). run a 1/4x20 bolt thru that puppy. You want this bolt to be tight and basically almost thread itself through. I also put a lock washer on this.
4. drill out holes for your u-bolts that attach to your head rest post
5. put in on, and tighten down all bolts.
6. mount your camera.
Total parts = $14.66
Total Time = 30 min (less if i had the proper size bit)
Old 05-08-08, 09:53 AM
passnu2
passnu2's Avatar
Man I love the creativity!
Thanks for the write up!
I need a DIY on how to take pics Maybe we can get Javier to do this one?!?!
Mike
Old 05-08-08, 10:38 AM
pisaykotik
pisaykotik's Avatar
So ingenious!
Old 05-08-08, 11:06 AM
caymandive
11 Second Club
caymandive's Avatar
Nice job Troy!
Old 05-08-08, 12:06 PM
ULTiMaX99
ULTiMaX99's Avatar
wow that's pretty ingenious! i wonder if you can buy a passenger headrest and rip off the headrest part to use the 2 poles and fabricate some sorta bracket to hold a camcorder on top of those 2 poles. then stick the camcorder into where the headrest should go. you'll have a passenger pov tho...
Old 05-08-08, 12:18 PM
DRivera250
DRivera250's Avatar
does the camera shake at all?
Old 05-08-08, 12:52 PM
1989Lexus
1989Lexus's Avatar
good idea!
Old 05-08-08, 01:01 PM
taylorjste
taylorjste's Avatar
very nice troy.. i'm assuming you're heading to ennis this weekend? when are you going? i've been looking for an excuse to go out there.. the weather forecast looks good..
Old 05-08-08, 01:51 PM
combfilter
combfilter's Avatar
Thanks all.
Taylor i am going out to MSR @ cresson. I posted an invite in the southwest forums but nobody was interested.
Old 05-08-08, 02:01 PM
gshb
gshb's Avatar
can we get some shots of what the camera sees? i assume you have to zoom it in to get more details on whats going on outside.
Old 05-08-08, 03:16 PM
Memout
Memout's Avatar
nice...
btw what's with the brown seatbelt :|
Old 05-08-08, 03:51 PM
combfilter
combfilter's Avatar
yea, after this weekend
Old 05-08-08, 03:52 PM
combfilter
combfilter's Avatar
Originally Posted by Memout
nice...
look at the other pics, it's not brown. I am at work and needed to brighten the pic. That is paint.net working it's "magic"
Old 05-08-08, 04:10 PM
Evitzee
Evitzee's Avatar
Nice, clean installation. Will be interested in seeing some pics after this weekend to see how the setup works.
Old 05-08-08, 04:40 PM
2slow
2slow's Avatar
Make sure you use somethin soft on the U bolts so they do not scratch up the headrest thingys.
I'm wonderin if it will shake still. Have you tried mounting it outside the car?
Quick Reply: DIY: camera mount for is350
