View Poll Results: After HID Kit install did you adjust beam pattern?
Yes I lowered the projector down
9.52%
Yes I raised the projector up
26.19%
No I left the projector at original factory settings
27
64.29%
Voters: 42. You may not vote on this poll
Aftermarket HID Kit Owners
Old 04-25-08, 07:02 PM
OutGolfn
OutGolfn's Avatar
Default Aftermarket HID Kit Owners
Did you all have to adjust the halogen projector beam down once you added the aftermarket HID? As I understand it the HID's make it brighter (light will go further) and with the original halogen projector beam pattern would shine to high and blind oncoming drivers.....
So if you could answer the poll and describe any other info you did once you installed the HID's would be helpful... Thanks...
Old 04-26-08, 05:31 AM
passnu2
passnu2's Avatar
I don't have aftermarket...but PM member Brian231 and he can help you out with this. I saw his install and he did a great job on it.
Old 04-26-08, 07:02 AM
Joeb427
Joeb427's Avatar
On my garage door with two piece of tape,Koz and I compared the cutoff height of his OEM HIDs and my HID kit.Mine were about 2-3 inches higher so we lowered each side to match his stock height.
Old 04-26-08, 08:44 AM
orbital817
orbital817's Avatar
Just curious, but I hear alot of people on here upgrade or change their HID lights. Is the factory HID no good? I currently own an A4 with Xenon HID lights and they are great! Why is Lexus's HID no good? Are they not Xenon's?
Old 04-26-08, 08:49 AM
MLIAISON
MLIAISON's Avatar
No they are, most people just like the brighter Xenons, or a higher Kelvin Temp for color (aesthetics only)
Old 04-26-08, 09:47 AM
Brian231
Brian231's Avatar
Most people swap out the 4200k for a 5000 or 6000k bulb with factory HID's. As for aftermarket, I put a 6000k and love it. I should lower my beam to compensate for the higher light out-put. Occasionally, I get flicked a high beam as oncoming drivers think my high beams may be activated.
Old 04-28-08, 11:57 AM
jns350
jns350's Avatar
I had to adjust my head lamp a few notches up. I also used my garage door and drove around the block a few times using parked cars for reference. Then I had a friend drive towards me and ask of I blinded him. Experiment
Old 04-28-08, 11:59 AM
Brian231
Brian231's Avatar
There is a Lexus Headlight Aiming PDF file floating around here for the 2gen. I saved it on my laptop at home and will find it to post to help out some members.
Old 05-08-08, 06:18 AM
passnu2
passnu2's Avatar
Its really easy to adjust! Its "just" the turn of one screw. Even if you have AFS and OEM HID. Many had mentioned 2 different levels. When I had the covers removed to install my Side Turn Signals we adjusted my lights also since I lowered the car. There is a sticker on the headlamp assembly that clearly states by turning the aiming screw it automatically changes the vertical/horizontal position.
With the covers on in the upper corner there will be a hole in the plastic cover so you do not need re remove them. Simply put a long (I believe it asked for a #2 Phillips) screwdriver threw and make sure you follow the aiming instructions Brian will post later. I cant seem to find the one I had but its also in the owners manual
Old 09-23-10, 09:13 PM
BradInPhx
BradInPhx's Avatar
Thread Revival, but I used search and couldnt find anything.
I just put 6000k HIDs into my IS350. The right side is slightly higher and I do not want to blind others.
I had the NON HIDS before, how do I adjust this?
Old 09-23-10, 09:27 PM
ISThree
ISThree's Avatar
for headlight adjustment
see this post (post #16 would help)
https://www.clublexus.com/forums/is-...-uneven-2.html
Old 09-24-10, 02:12 AM
ldc
ldc's Avatar
Adjust the lights to your liking....there's no ONE position for everyone.
Old 09-24-10, 10:55 AM
Synetix250
Synetix250's Avatar
Post
the driver's side light should be a little lower than the passenger side, that's a lexus factory setting so you don't blind oncoming driver's coming around corners. i have an aftermarket kit and actually want to raise the beam a little higher but after reading this thread, i might keep it as is-factory level.
Old 09-24-10, 11:58 PM
chikoo
chikoo's Avatar
It is factory setting on all cars since quite a few many years so that so you don't blind the oncoming driver.
Old 09-25-10, 03:07 AM
kumquatism
kumquatism's Avatar
I raised mine up. I'm not sure if the previous owner was tinkering around with the beam level, but it seemed far too low. The lowbeam barely light up 30 feet in front of me. I adjusted it in comparison to my cousin's 07 camry's factory settings. Her car is aimed fairly high, I have mine just a tad lower than hers. I tested it around the neighborhood, as well as tailing my friends while they drive. I got no complaints from them about it being blinding or anything of the sort. If I'm behind someone, my cutoffs sit right aroud their bumper area.
truenoboy
Lighting
04-05-08 07:42 PM
Ishinc
10-13-06 10:20 AM
06Harrier
08-19-06 01:21 PM
witmaRX
RX - 1st Gen (1999-2003)
07-21-06 06:28 AM
WUTANGSC300
SC- 1st Gen (1992-2000)
11-08-02 01:40 AM
Quick Reply: Aftermarket HID Kit Owners
