Smoked taillights. Perfect install! 56k WARNING!! =D
Old 03-01-08, 10:28 AM
sab504
sab504's Avatar
Default Smoked taillights. Perfect install! 56k WARNING!! =D
Hey guys, havent posted on here for awhile, been busy, but I wanted to post some pix of the smoke vinyl taillight install that me and my friend did. Took us about 1.5 hours to finish the job. Was pretty smooth from start to finish. Did it around end of January. Got the film precut for cheap on ebay from a guy name firearm01. Much better than painting your taillights imo. Finally had a chance to take some pix.
Old 03-01-08, 10:45 AM
f=ma
f=ma's Avatar
god thats dark
Old 03-01-08, 10:54 AM
sab504
sab504's Avatar
The camera actually makes it darker than it seems. It is NOT that dark. It is not blackout, it is smokeout.
Old 03-01-08, 11:01 AM
ExTrEmE99
ExTrEmE99's Avatar
Looks clean but i would prefer red out but i like the smoked out reflectors, i was thinking about doing the same for the reflectors..
Old 03-01-08, 11:08 AM
sab504
sab504's Avatar
I had my tails redout for a whole year plus. Was getting tired of the look so wanted to do something different for a change. I REALLY like this look right now and it only cost me about $40 to do this. I can always take them out and redo the reds if I change my mind. Thats whats modding is all about!
Old 03-01-08, 11:16 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Not bad
Old 03-01-08, 02:30 PM
Bigrahizzl
Bigrahizzl's Avatar
Thats HOTT!!!!!!!!!. I bought from the same guy, cool person to deal with.
And i have to tell you, you did a pretty good job. PERFECT!
Old 03-01-08, 02:46 PM
97-SC300
97-SC300's Avatar
That looks amazing!
Old 03-01-08, 04:22 PM
sab504
sab504's Avatar
Originally Posted by 97-SC300
That looks amazing!
Thanks!
Now all I'm lookin for are some nice racing type 19s. Any recommendations from clublexus?
Old 03-01-08, 06:17 PM
Fiko18
Fiko18's Avatar
work rims, how did u get it so perfect, any tips
Old 03-01-08, 07:10 PM
sab504
sab504's Avatar
When installing the vinyl, you will definitely need another person helping you. The blow dryer is your friend, so use it often when installing the vinyl. It will help line up the curves on this taillight. Heat up the vinyl for about 3-4 seconds on hot air so that you can stretch the vinyl then flatten it against the surface of the taillight. Its kind of hard to explain unless I am physically doing it, hope you get the idea though.
Old 03-04-08, 04:53 PM
gman1227
gman1227's Avatar
ok so i ordered for the same guy u did and when i stated to do the out side it did not work at all. the lil corner piece was being a pain. so u just heat it up and stretch? and will the rest of it stay in place. how important is another person?? thanks really want the smoked tail lights really really bad
Old 03-04-08, 04:54 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
That is a huge contrast!
If you can pull it off, go for it! Make sure you do limo tints on the windows and get black wheels...
Old 03-04-08, 04:56 PM
josh250
josh250's Avatar
dark as hell
nice!
Old 03-04-08, 04:59 PM
Bigrahizzl
Bigrahizzl's Avatar
Dude once you start off with the hair dryer you will get the hang of it. Once the vinyl is heated it becomes relaxed so once you place it over the curve, it contures with it. MAke sure you have a credit card or squeege wrapped in a thin cloth to help you sit the vinyl down with. This also helps alot. Once you sit the vinyl down blow it with the hair dryer again so the the water underneath drys up a bit, dont hold it the just go over the area a couple of times with it. I hope you get my point, its a very easy install.
Quick Reply: Smoked taillights. Perfect install! 56k WARNING!! =D
