DIY aftermarket amp power wire install step by step with pictures - Page 5 - Club Lexus Forums
Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - 2nd Gen (06-13)
Sign In
Register Forgot Password?
Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Thread Tools Search this Thread
Old 12-08-09, 11:50 AM   #61
xuningshen
Trader Score: (1)
xuningshen's Avatar
like MV350, mine is also plugged into my fuse box with something similar to this. not exactly the same product i bought but similar
http://www.amazon.com/Pico-0957PT-Fu.../dp/B001QRSBY8
Its not hard to run the wire. i had my rear seats taken out when i ran the power wire so it was super easy to just run this one. took an extra 10-15 minutes once i tapped down the wire as i ran it under the scuff plates etc.
For me, the less i splice into existing factory wiring the better. thats why i went this route. Its wayy easy to disconnect also lol
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
06|Crystal White|IS 350|
http://www.flickr.com/photos/naickoilss
xuningshen is offline   Reply With Quote
Old 12-08-09, 12:15 PM   #62
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
Question- do you guys tap both pos and neg for the sub? Brown and pink + then skyblue and green -??? Or do i only have to just tap one pair?
__________________
mIStaSC is offline   Reply With Quote
Old 12-08-09, 12:17 PM   #63
xuningshen
Trader Score: (1)
xuningshen's Avatar
both of us didn't tap the sub wiresMv350 did his install then he helped me out with mine lol, our setups are identical). i tapped my front right woofer wires, positive and negative, can't remember what color they where off the top of my head, i'm at work and didn't drive the carpool today.
__________________
Old 12-08-09, 12:26 PM   #64
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
Those colors would be red and white and then the other pair is brown and pink.. Those are the colors for the FRONT speakers. So you didnt tap into the factory sub???? Then what wires did you tap? I only tapped one pair of pos neg and its working. But my question is should i tap both pairs since therss four wires for the stock sub because its a dual voice coil.. So tap one pair or both?? Or if i do both it wouldnt mAtter??
__________________
Old 12-08-09, 12:32 PM   #65
nmpeter
Trader Score: (15)
nmpeter's Avatar
nmpeter
I didn't mess with the stock amp wiring myself but I remember lime green brown pink and sky blue being used only. I forgot which order they go in.
non ml
nmpeter is offline   Reply With Quote
Old 12-09-09, 01:55 PM   #66
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
Yeah brown and pink is pos and skyblue and green is negative. That is the wiring color for the stock non ml sub. So you did tap into both pairs.. I only tapped into one pair and my question was should i do both pairs
__________________
Old 12-09-09, 10:49 PM   #67
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
I didnt have to splice anything. I used t taps for all the wiring. Only wire you actually have to run is the power wire. All the other wires can be t tapped from the amp in the back including your remote wire. Hope this is helpful information for the non ml owners who want to install a sub
__________________
Old 12-09-09, 10:52 PM   #68
nmpeter
Trader Score: (15)
nmpeter's Avatar
nmpeter
Damn I didn't think about using t taps. I'll do that when wire my sub back up.
Old 12-10-09, 11:41 AM   #69
xuningshen
Trader Score: (1)
xuningshen's Avatar
oooh my bad misread your question. to try and answer it(my horrible attempt). i only tapped one pair of positive and negative, but then again i tapped the front woofers not the sub. i probably should've tapped both for Left and right. I did use T taps so i didn't have to cut completely.
Instead of tapping both left and right pairs. I only tapped my right side and made these Y wires to go into both the LEft and Right positives and negatives in my line output converter.
So front woofer positive wire went into both the front and left positive on my LOC
and front woofer negative wire went into both the front and left negative on my LOC
So in essense its only playing signals from my right woofer. but bass is usually pretty balanced when it comes to left to right balance. so i figured i'd be fine.
I hope i explained it correctly and it makes sense. but this doesn't apply to tapping the sub wires i don't think. i'd recommend tapping the front woofers because people have said they loose mid bass when just tapping the sub wires.
__________________
Old 12-10-09, 02:42 PM   #70
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
nope you didn't answer my question haha are you running a sub??? did you t tap into the sub wires(the two pairs i mentioned above) for your sub? and then you t tap the front speakers into the LOC? or all you did was just t tap your front speakers which makes me confused as to why you would only do that lol
well anyways. so about the tapping of the front speakers. all you did was just tap it and hook it up to the LOC? or do you have to adjust it or something? i tapped the right speaker only(didnt Y wire it up like you i just did one pos and one neg onto the loc) so far and i don't think i hear a difference lol or must i adjust the gain on the LOC?(i think there was something adjustable on the LOC).. i'm too lazy to look right now lol
__________________
Old 12-10-09, 03:21 PM   #71
xuningshen
Trader Score: (1)
xuningshen's Avatar
Lol ops sorry i'll keep trying i guess. just let me know when to stop haha.
ok so. if you tap your front "woofer" wires you get allllllll the bass/low signals you need to run your sub and get the deep deep bass. you even get all the highs i think. I just set my amp to only bump out the lows since i only have subs hooked up.
So i T tapped positive and negative front "woofer" wires into my LOC and from my LOC i ran RCA cables into my amp.
I just bumped up the gain and then adjusted the rest on my amp
really? you just have one positive and one negative into your LOC and its working fine? interesting haha, i guess it would work.
__________________
Old 12-11-09, 06:01 PM   #72
mIStaSC
Trader Score: (17)
mIStaSC's Avatar
THIS PART! lol i took a look at the SCOSCH LOC today. how do you know and what setting did you set the gains to?? all the way +??? thats what mine are at. I need to buy more T taps to do the other speaker.
__________________
Old 12-11-09, 10:17 PM   #73
Mv350
Trader Score: (23)
Mv350's Avatar
Mv350 Mv350 Mv350
man i wish i was in fl to help you. on the scosch loc set them to the center, its easier to do it off the amp. play with the gain and ohm nominance, the settings on the LOC are to touchy. set them neutral in the center and USE THE AMP, less touchy, it creates an overall clearer sound. if you have an amp the has the ability to run a bass/gain control *** that is the easiest way to play with it, without having to go into your trunk
__________________
innovation that really makes you wonder
What in the world am i not driving a Toyota... LEXUS
Mv350 is offline   Reply With Quote
Old 02-20-10, 08:27 AM   #74
rselby
Trader Score: (0)
rselby's Avatar
OK...did anyone ever find out??? do we need to use both sets of + and - for the non ML subwoofer???... or just 1 + and - ???
__________________
08 ISF | Joe Z | aFe dry flow | S4play | LED fogs | Magnaflow exhaust | PPE headers | FIGS | Michelin PSS | black pearl trim |
rselby is offline   Reply With Quote
Old 02-20-10, 08:44 AM   #75
ISooNice
Trader Score: (0)
Quote:
Quote:
he said he used one pair and it's working
__________________
2008 IS250 6spd!!!!
ISooNice is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
NY FS...Pioneer avic-D3 $300 shipped obo kraven9 Mobile Audio/Video Classifieds 1 08-02-14 10:09 PM
superiorconcepts UCF10 build........ SuperiorSC Build Threads 33 05-25-10 02:55 PM
RX Twin Exhaust vlamos RX - Second Generation 67 11-07-07 12:31 PM
Black IS350 after Meguiar #80 and NXT Tech Wax tt061880 IS - 2nd Gen (06-13) 40 07-30-07 09:44 PM
Nudge Bar RX350 & Accessories vlamos RX - Second Generation 25 05-21-07 05:13 PM
Tags
3000gt, aftermarket, amp, change, diy, fai3a, ground, is350, lexus, ls430, power, remove, subwoofer, turn, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
