Navigation Hack Alternative - Hybrid Nav DVD
#61
You need to pull the fuse for the navigation unit. The one marked "TV". This will force the re-load of the older firmware... Try that...
#62
istundra:
be sure you burn the disc using ISO 9660 format. Don't burn it using UDF as it won't read that type of disc.
Use imgburn (do a google search for it) to create an iso image which you then burn.
This worked for me.
This worked for me.
#63
It's NOT in the glove box on the IS250 or IS350. The nav DVD is located BEHIND the clock face that is below the nav screen. There are two small holes to access it. There is a tool that comes with the IS to do this. You pop the face off and then eject the disc via the nav interface. Do a search, you'll find pics and links...
thx
josh
#64
#65
I also used some 3M double sided tape to help me remove the clock panel.
I taped the 3M tape on the clock panel and the other end on something flat.
Once i inserted the clock removal tool... I pulled the piece with the tape stuck onto it... and it came out fine.
do not use a pry tool.. u will scratch the clock panel.
#66
Tech Info Resource
Pics can help understand.
#67
Seems that this is not exactly a fix. Some functionality enhancements require a firmware update. If you use the 05 series load file, you aren't going to be able to benefit from some of the fixes. This just allows you to use the map data and maintain the software bypasses.
#68
Tech Info Resource
To what fixes and functionality enhancements are you specifically referring?
#69
Super Moderator
#70
Tech Info Resource
That's why I'm asking - to be sure there isn't something else I'm missing by keeping my 1600 (not 1550 or 1650) firmware version. If there is additional functionality greater than maintaining lock on the birds, I'd like to know. I'm not (and never have been) having an issue with locking on multiple satellites at all.
#71
#72
Super Moderator
Before switching to the old version of the software, read the early posts in this thread: https://www.clublexus.com/forums/sho...d.php?t=230294 to see the kind of problems that some users of the older software were having. For some reason, never definitively determined (heat problem? atmospheric conditions?), most of us with the problem had the most trouble during the hot summer months.
#73
#74
I haven't seen the version history but I'm sure there are some bluetooth and phone compatibility fixes, maybe some additional voice commands etc... included as well. Some of these fixes would not make it in with the method described because you need the 06.1 loader.
Maybe a better way of confirming is to see if anyone that has the 05.1 loader with the 06.1 disc has the autorecirc fix functioning. If it isn't, there is a clear indication that the workaround just enables you to use newer map data and maintain the shortcuts.
I'm not trying to minimize anyones work so far, we all appreciate it, but I think the benefits need to be further explored/explained.
#75
As with all firmware fixes, if you aren't experiencing any problems, don't worry about it...
There are 100s of people on this forum with 2006 ISx50s, who have the V5.1 disc and have ZERO problems... Using this method is just like having a 2006 ISx50, no difference...
If you are having problems, then use the newer firmware and lose the override...
Or, do what I did and install an override switch + the newer firmware...
