Old 12-15-14, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Fast Install of Illuminated Scuff Plates
Old 03-02-10, 03:18 AM
  #181
RickJames1
RickJames1's Avatar
is this so easy a caveman can do it? lol but seriously ive only changed my dome and puddle lights kinda scared about this one. is it hard to do without any exp on this?
Old 04-12-10, 04:45 PM
  #182
vedder
vedder's Avatar
Are there any '10 owners that have actually tried this? The dealership cannot give me a straight answer...
Old 04-12-10, 08:07 PM
  #183
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Here is your answer.....
2010's are NOT plug & play for Illuminated Door Sills
Joe Z
Old 11-14-10, 11:05 AM
  #184
25Obsidian
25Obsidian's Avatar
If i want to use a wire tap to tap into the grey wire, do i still need to cut the grey wire flush from the connector?
Old 11-14-10, 11:43 AM
  #185
MSirJet
MSirJet's Avatar
I just installed mine yesterday... here's how I did it:
I taped into the foot well light for the ground on both sides as I wanted the fade effect.
Didn't use wire taps, they are subject to intermittent condition and can actually sever the wire as the wires used are very small (24 - 26 ga). I soldered directly to these wires about an inch back from the connectors:
RED wire at the footwell light connector (both sides)
WHITE wire at the existing connector at the harness beneath your existing sil plate.
Used 22ga wire for the jumper, strip back about 1/4 inch of insulation with an exacto knife about an inch back from the connectors (after gaining access of course, the close out panels just pull right off, the drivers side has two screws that have to be removed, there obvious). Soldier your jumper wire to the footwell light connector RED wire first, re-insulate with tape(black electrical), use some wire loom covering(that black tubing with the slit running the length of it) and route to the door sil harness. Use same method to attach the other end of your jumper to the WHITE wire at the existing door sil connector. You do not cut any wires, just strip back enough insulation to soldier your jumper to it.
take your time cutting the existing tape wrapping the harness and striping the wires, you should not have a problem if you are careful. After making the footwell connection take not to short the jumper when you are routing it back to the sil connector as it will now be your floating ground so will have a positive potential(voltage signal).
Hope this helps... btw i did this on my 2006 350.
Good luck friend.
Old 08-19-11, 02:40 AM
  #186
Rufio808
Rufio808's Avatar
So the red wire that you tapped into from the door switch is soldered to the grey wire from the existing plug?
Old 06-25-13, 11:53 AM
  #187
suka4thong
suka4thong's Avatar
i have pre-06 base model and just received white ISP
which wires do i have to tap?
Old 06-25-13, 01:05 PM
  #188
mattsti10
mattsti10's Avatar
Awesome write up, this will come in handy when i decide to install my illuminated sills.
Old 07-07-15, 02:35 PM
  #189
adpock
adpock's Avatar
Default Front Page News!
great stuff. thought the front page would be interested too...
https://www.clublexus.com/articles/h...-scuff-plates/
Old 07-08-15, 07:29 AM
  #190
boosted4.6
boosted4.6's Avatar
Nice! Very clean looking
Old 09-21-15, 10:27 AM
  #191
10lexISR6
10lexISR6's Avatar
Just got mine yesterday for my 2011. Let's see how this goes. Thanks for all the input.
Old 10-05-15, 09:37 PM
  #192
10lexISR6
10lexISR6's Avatar
Just installed mine to the under dash lights. I noticed they do not turn off ever while the car was running. Anyone have issues with it yet? Longivity?
Old 10-14-15, 09:33 PM
  #193
10lexISR6
10lexISR6's Avatar
UPDATE: rewired my sills lights to the door switch. I didn't like that they done turn off except when the car is off. Unnecessary wear on the leds. I can easily change the under dash leds but not the ones in the sills. The fade in effect looked cool hooked up to the under dash leds, but you have to open the door quickly to notice that they actually did that. Most people wouldn't notice. I also believe the overall light output to the sills was significantly dimmer hooked up that way, versus to the door switch.
Old 03-16-20, 05:47 PM
  #194
davidbusta
davidbusta's Avatar
Where do I get the illuminated door sills at? are they plug and play on a 2006 IS with the premium package?
RXGS
10-06-20 08:22 AM
9600baud
07-09-13 04:46 PM
fj40ih8mud
05-05-13 04:11 PM
philly777
GX - 1st Gen (2004-2009)
01-18-09 08:39 PM
scottc25
IS - 1st Gen (2001-2005)
06-15-04 07:25 AM
Quick Reply: Fast Install of Illuminated Scuff Plates
