IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Back speakers
Old 03-14-17, 04:47 PM
Chrisl0214
Chrisl0214's Avatar
Default Back speakers
How to take off the cover to the back speakers
Old 03-14-17, 08:57 PM
MIA_LEX
MIA_LEX's Avatar
Pull up on the seat bottom, pull it out the car. 4 12mm bolts holdibg seatback in. Up and out. Then there are 3 10 mmbolts on top. You also gotga take out the c pillars.
Omen766 (04-04-17)
Old 03-18-17, 09:15 PM
NERD42
NERD42's Avatar
If you are trying to remove the grills they are held in by tension washers that slide onto plastic tabs underneath; after following above instructions to remove the rear deck.
Old 03-19-17, 07:57 AM
Vitveet
Vitveet's Avatar
Those 2 guys above are correct! Also, if you need spacer/adapters to fit traditional 6x9s or a 6.5 or whatever you want to fit, pm me as I make them.
As you may know, a traditional 6x9 won't fit in OEM location after the OEM speaker is removed.
V.
Omen766 (04-04-17)
Old 03-27-17, 10:10 AM
01MSMSXE10
01MSMSXE10's Avatar
just like mia and nerd said. You've got to remove the rear seat and the c pillars.
Omen766 (04-04-17)
Old 04-04-17, 08:41 PM
Omen766
Omen766's Avatar
Ya i bought my 300 a month ago and the back speakers are blown the **** out. Found out u gota take out the whole ****in back seat to get to the speakers ahah.. pretty easy tho luckily.
jdmba
18
12-01-10 08:13 AM
jung502
10-09-02 05:46 PM
kyfucius
08-31-01 08:46 PM
simonywong
07-22-01 08:58 AM
Quick Reply: Back speakers
