IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Any Phoenix area shops for engine work?
Old 11-24-16, 07:08 AM
Terraplane
Terraplane's Avatar
Question Any Phoenix area shops for engine work?
Looking for a good shop that knows the 2Jz engine in the Phoenix area that is trustworthy and reasonably priced. I need someone to pull the head so I can take it to a machine shop, I'm pretty sure I've got a sticky valve. I've got Brian Crower cams, fyi. I'm friends with a mechanic...even have a key to his shop, but he's got a lot of personal things going on and I need to get this going. I'm in 85020, north central Phoenix.
I want to stay as FAR away from the stealership as possible. Small hole in the wall shop that does great work would be perfect...but I'd like familiarity with the 2JZ-GE motor. Toyoworks who put in the cams (and bent the valves...replaced, long story) doesn't like to do aftermarket work. Great shop, but not the one for this. If you recommend someone...please add a little bit as to why. Thanks everyone-Chris
(p.s., experience boosting the IS is OK, too :-)
Last edited by Terraplane; 11-24-16 at 07:16 AM. Reason: Added a note about boosting
smomin23
Southwest
01-10-15 06:02 AM
Lexatlast
NELOC
09-14-09 08:09 PM
madmax98
CL of Southern California
01-14-09 01:03 AM
indelible
10-09-05 01:09 PM
Quick Reply: Any Phoenix area shops for engine work?
