IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Magnaflow Catalytic converter
Old 03-18-16, 07:03 AM
Jonair
Jonair's Avatar
Default Magnaflow Catalytic converter
Hello guys, anyone from you guys have a recommendation? im supposed to replace my catalytic converter, aside from oem part. I saw this magnaflow California legal, any thoughts about it? Thank you.
Old 03-18-16, 01:30 PM
jadu
live.love.laugh.lexus
jadu's Avatar
My only thought is usually those magnaflows need to be welded. Unless you are going to weld it on yourself, you may need to take it to an exhaust shop to weld it on. GL
Old 03-18-16, 01:34 PM
Jonair
Jonair's Avatar
Hi Jadu, thanks for replying, the guy said from the store..should be a direct fit, no modification needed....but you think magna flow is gonna work just like the oem?
Old 03-21-16, 01:12 PM
jadu
jadu's Avatar
Direct fit is a plus-no welding that's for sure and I'm sure it will work just fine
Old 03-22-16, 02:47 PM
Jonair
Jonair's Avatar
Tnx, appreciate your input, i will review it. So im fixing my catalytic then...its making another problem like p0442 and etc. ?
Old 04-11-16, 11:19 PM
Jonair
Jonair's Avatar
Jadu, the manga flow direct fit exhaust manifold did work just out fine, no check engine so far. Thanks again.
Old 04-14-16, 12:56 PM
DrMcPho
DrMcPho's Avatar
Jonair, did you get the P420 and P430 codes at the same time? I'm having the same issue and don't know what cat would be good for CA standards.
Old 04-15-16, 12:03 AM
Jonair
Jonair's Avatar
Yes, same situation, same codes. I got mine from Hot Exhaust ask for for the magnaflow California compliant, direct bolt on. I got it like for $700 plus something...you can get a coupon in their own site....I was so hesitant getting this product, but it worked for me... No more issues at this moment. I have more than 250 miles since I have the new manifold exhaust. Good luck!
Old 04-17-16, 09:59 PM
stanghater
stanghater's Avatar
I saw the Magnaflow y pipe and headers for a total of about $1500. Thats a LOT of dough. Pacesetter has the same parts for about $600 total. Ive actually had decent results with pacesetter in the past. Their problem is they surface rust bad, even the coated ones. What ive done in the past is VHT all the pacesetter pipes and have had no problems. Just something to consider
YODAONE
12-06-16 07:52 AM
chenxingha
RX - 1st Gen (1999-2003)
10-18-10 08:14 PM
92sc3forme
Performance & Maintenance
13
03-10-09 08:57 AM
Lextasy89
Performance
51
03-06-08 12:13 PM
actuary
11-22-05 10:01 PM
Quick Reply: Magnaflow Catalytic converter
