IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Belt Pulleys
Old 03-06-16, 04:02 PM
17s
17s's Avatar
Default Belt Pulleys
Well I just had my serp belt get mangled because of a bad pulley bearing, most likely the power steering pulley from what I could tell. Had to drive it 6 miles without the belt, as soon as I pulled into my driveway, coolant started spraying from somewhere, cant identify the source.
Anyways, what I wanted to know is could the two be connected in any way?
Also can I purchase the pulley itself or do I have to buy the entire power steering pump?
Old 03-07-16, 05:34 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
without the belt on, the water pump doesn't move coolant which means localized overheating.
You should have gotten the car towed - that could mean a blow head gasket.
the part of the pulley that spins is part of the pump - the pulley can't stop spinning - only the pump.
I've never seen a 2jz power steering pump fail - I would check the rest of the pulleys first
2jznosht
Performance & Maintenance
06-20-23 10:35 AM
tianh
03-04-12 12:47 PM
rsen99
01-17-12 08:22 AM
Dexterw
RX - 1st Gen (1999-2003)
12-16-09 04:28 AM
Quick Reply: Belt Pulleys
