IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Do supra twin turbo wheels fit is300?
Old 03-05-16, 09:20 PM
tenac2215
tenac2215's Avatar
Default Do supra twin turbo wheels fit is300?
Saw a couple different responses while searching and was looking for a definitive yes or no? Thanks!
Old 03-07-16, 05:28 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Yes and no. The front steering knuckles need the little nub to be ground off for them to fit, and then the wheels better be perfectly round or they will rub.
Rears fit no issue.
I run 235/45-17 on the front, 275/40-17 rear, rears required the fenders to be trimmed.
Old 03-07-16, 07:06 PM
tenac2215
tenac2215's Avatar
Rears fit no issue.
I saw that you could use a spacer in front to avoid the steering knuckle issue, would that work?
Old 03-07-16, 07:10 PM
mitsuguy
mitsuguy's Avatar
You can, I am just not a fan of spacers. even a 3mm spacer (I have a pair I tried) set the wheel out too far and made it no longer hubcentric. Since the lug nuts are shank style, they really should be hub centric-ly mounted.
Old 03-08-16, 04:48 PM
mitsuguy
mitsuguy's Avatar
Here ya go
Old 03-09-16, 09:52 PM
the.wong.k
the.wong.k's Avatar
Rears fit no issue.
^what he said, also the front wheels need to sticky weighted on the inside, no hammer weights on the inside lip because they'll catch on the knuckle. i run supra turbo wheels on my winter setup haha
JonnysES
06-12-13 07:03 PM
BrentGS
GS - 1st Gen (1993-1997)
06-14-10 09:42 AM
TecnoSmurf
SC- 1st Gen (1992-2000)
12-03-09 09:36 AM
the2ndr
08-22-08 01:21 PM
phrozen
07-22-08 10:53 AM
Quick Reply: Do supra twin turbo wheels fit is300?
