Crush washers for oil, trans fluid, and diff fluid
I wanna replace the transmission fluid on my car and am wondering if the crush washer is the same for the transmission drain plug and the engine oil drain plug?
For that matter, is the rear differential plug crush washer the same?
I ask because I found crush washers for the oil plug on Rock Auto
Thanks in advance for the help.
picked up from dealership
I ended up buying the appropriate washers from the dealership.
The rear differential crush washer has a 24 mm outer diameter and a 18 mm inner diameter. It is the same washer for the transmission, too. Both transmission and diff take two washers each, four total.
gemigniani
ES - 6th Gen (2013-2018)
24
07-07-17 06:59 PM
ktmjay
RX - 1st Gen (1999-2003)
10-12-13 05:57 AM
